Mountie... have a look at the video (link below). Any more questions feel free to ask.
Just one question - where do I get one?
Already replaced my shock bolt cause it snapped.Hi All, Just a word of warning and something to watch out for - my bike (Turbo Levo basic model) started making the most horrendous creaking noise last week: I called Specialized and they isolated it to the head bolt for the rear shock Connecting the crossbar). The bolt had sheared completely and could have failed at any time, which would result in the bike collapsing and, no doubt, me getting a mouthful of tree / mud etc. The guys said they had not seen this problem before and will be sending the bolt back to Specialized to ensure it was a one off issue.....
So, if yours starts to make a loud creaking noise, check the rear shock mount head bolt- it should not be loose in any way!
I’d let Specialized know if you haven’t already .....Already replaced my shock bolt cause it snapped.
The most likely cause for the failure is the bolt coming loose and since it is supposed to be assembled with thread lock, either was not done originally or that bolt has since first build been removed (e.g. to run a dropper cable) and not thoroughly cleaned and new thread lock applied. Care also needs to be taken not to get any grease on the threaded section of the bolt. Note that any disturbance of the bolt....to tighten etc....will render the thread lock useless.I’d let Specialized know if you haven’t already .....
Thanks. Worth knowing. ?The most likely cause for the failure is the bolt coming loose and since it is supposed to be assembled with thread lock, either was not done originally or that bolt has since first build been removed (e.g. to run a dropper cable) and not thoroughly cleaned and new thread lock applied. Care also needs to be taken not to get any grease on the threaded section of the bolt. Note that any disturbance of the bolt....to tighten etc....will render the thread lock useless.
Actually realised that my brakes are Code R not Guides.Just on the brakes. I had to emergency stop on my 4 rides old Guide R's to avoid a car and TBH they performed as well as the XT8020 on my other bikes. They seem to have more modulation under steady braking than the XT and don't immediately bite so hard. At the end of the day they are both great sets of brakes. Anybody here remember rim brakes![]()
I’ve heard chains needing to replaced at the first complimentary service, 10 hours worth of riding!600km blimey that seems low mileage on a chain
Once you ride it …….Doesn’t taking the motor out void the warranty ?????!!!! Don’t pick my levo up till Monday & im wondering if I’ve made the write choice.....
250 mile in 2 months since new.
Just popped the motor case off to check for water mud ingres .
Clean and dirt free, the bike gets used in wet muddy woods most weekends.
I like the tinkering side as much as riding and have a reasonable tool set from yrs of motorcycle servicing , No pressure washing helps I think with keeping bikes in tip top order
Touch wood my service regime will keep the bike working as it should.
Which XD hub is a good one? Now I have a NX cassette and i’m thinking to buy a gx cassette
I changed chain 400miles again at 1000 . Cassette looking crap since about 500miles to be honest now done 1400 muddy miles still not jumpindChris of Berkshire advice was run chain etc till starts jumping then do complete drive train . That's working out for me just clean and oil chain most rides. It's filthy in half an hour any way so don't see point in being too fussy.So after 600km on the Levo most of it being wet and muddy i’ve had to replace a chain, rear brake pads and have the motor out to clean as there was a loud creaking noise. I have also broken a rear spoke.
Is it unusual to take the motor out so often?
Should the chain be replaced sooner rather than later ? And at what % wear ?
I was told to put nothing on any seals from Berkshire cycles seen a lot of damaged seals seemingly . Too much variation on advice on here I think.Dielectric grease around the seals on all electrical connections.
Chris at BC told me the same, then I was told to use the dielectric grease by a mechanic at Specialized head office in Chessington! It’s silicone based so safe on seals, I was told, plus the amount used is tiny and on the connector seals only. Using Vaseline or general grease is not recommended.I was told to put nothing on any seals from Berkshire cycles seen a lot of damaged seals seemingly . Too much variation on advice on here I think.
I put vaseĺine on and sprayed connection with electric cleaning stuff been ok. To be honest I just wipe with cloth seems ok. Got hit by a wave Sunday went oh sugar waiting for motor to konk out but all was ok. Sometimes I think we are being too fussy and cleaning to often.Chris at BC told me the same, then I was told to use the dielectric grease by a mechanic at Specialized head office in Chessington! It’s silicone based so safe on seals, I was told, plus the amount used is tiny and on the connector seals only. Using Vaseline or general grease is not recommended.
I am at about 200km and found grittiness in rear wheel bearings. Took it apart and it’s the freewheel bearings, wheel ones seem fine. I am washing often and have been out in terrible conditions too. Found water inside the freewheel, looks very clear so I am assuming it’s the washing doing it.
I am also using a dog dryer to blast the water off. I am wondering if this is doing more harm than good and just blowing water into bearings.[/QUOTE
If you've only done 200km I would think you have a dodgy freewheel , how many times have you washed it ? . I'm at 1500 miles probably washed 40 times and no issues.
