Slippery but fun. Had to hose my shoes off just to get clean enough to drive home.
You must scare the crap out of people on the trails if you wear the full Predator costume ..
Hullo tree...
This is the down side of riding in a warmer climate - "bird watching" whilst riding and becoming distracted ...
Not guilty, m'lud. Or, at least, not this time... Was my riding companion who has recently converted from road bikes but is still not convinced that tyre pressures shouldn't be at least 70psi. Rough downhill with roots - on a hardtail with even harder tyres. He bled a bit, but I'm not nasty enough to do that kind of photo...![]()
I'm surprised he could see where he was going, you'd imagine his eyeballs were bobbling about like a golf balls in a blender.. Quite lucky he had his helmet on looking at that !
More likely the "I was runing too low pressure" factor
an expensive lesson hopefully learned![]()
Not really sure what you think you're disagreeing with.25 psi... checked before leaving this morning.
It was my weekly coffee ride with the elderly gents (in their 70s, so no jumping and all road/hard pack track). Else, I'd more than agree with you.
Your tyre has ripped at the bead where it exits the rim edge.
this only really happens from either a large impact, friction over a period time (due to the tyre moving/deforming) or cutting/chafing from a damaged rim edge.
it doesn't happen with higher (more supportive tyre pressure).
I've no idea what you weigh or how/where you ride but 25psi in a 2.5 rear tyre is unridable for me at 200lb as the sidewall will fold cornering.
Rekon's aren't a great tread design unless you only really ride dry armoured/manmade/hardpack forest paths and the like but the casings are absolutely fine when run at aproipriate pressures. (Being the same casings as other Maxxis tyres)
Pretty much all tyres have pressure info built into the moulds. it's very rarely accurate. and the max pressure they rate tends to er on the cautious side (just to cover their own backs from recourse really)rated as 20-40psi
and the answer is... Huck Norris
VERTIGO!!
