Bike arrived with no instructions yet help!
Fx1
Auto WARNING : Possible Duplicate user : "Zero"
Feb 6, 2020
267
203
GB
Hi.
Got a few questions.
Wtf is the plastic thing behind the cassette? Can it be removed?
Also why did they install the brakes backwards and do I need to change the cables or just switch over?
Fx1
Feb 6, 2020
267
203
GB
Also. Does anything important come in the box that hasnt arrived yet?
b45her
94
87
wales
1 it's called a dork disc and yes you can.
2 the brakes are all fitted that way in Europe. Some can be flipped others need the hose swapping.
3 should have gotten a bike from a shop if your this green with bikes direct brands are a bad idea.
Fx1
Feb 6, 2020
267
203
GB
Never had a dork disk before. My s works didnt and neither did my stumpy.
Ironically the specialized bikes came in this build condition in the post. Not sure what I'd gain from a shop other than cost.
Never seen goofy brakes before and I know that you can reverse codes but the hoses are now gimpy.
Local shop can fix anything that isn't a warranty problem.
Fx1
Feb 6, 2020
267
203
GB
I'm guessing the charger is in the other box!!
Fx1
Feb 6, 2020
267
203
GB
The bike is up and running. Turns out that when the battery is low you cannot get the app to work. So I'm stuck in low power mode for now
Removing that dork disk was a PITA. I cannot find my tool to remove the cassette since I moved house. I have never seen a high end bike come with one before.
Fx1
Feb 6, 2020
267
203
GB
It's not a high end bike.
Hope that helps ;)
Lol.
Well I do have other high end hobbies to pay for aswell
Gary
Old Tartan Bollocks
10,496
10,690
the internet
Ah... I guess it's also so clean because it didn't come with instructions either.
bummer! ;)
Fx1
Feb 6, 2020
267
203
GB
bummer! ;)
Lol no because it come with 1 bar of battery.
Charger comes tomorrow.
Punisher
28
20
Fr
Battery is overrated. Keep it off and go ride mate.
Pass fast some guys and cry "Sorry to be so slow, I am waiting for the charger."
Fx1
Feb 6, 2020
267
203
GB
Lol.
It's got ceramic coating on it so the dirt comes off with the rain. It's not that clean on closer inspection.
I might apply it to the bike actually as well. Make cleaning it much easier.
Fx1
Feb 6, 2020
267
203
GB
Anyone know why I cant turn on the bluetooth in the menu? Web shows bluetooth LE but it's not in my menu
Fx1
Feb 6, 2020
267
203
GB
Yes thanks.
I worked that out. Must be a newer method as all videos online show you activating it.
Took me ages lol
seamarsh
350
174
usa
I just scored it with a utility knife and broke it off, easy as pie.
Maherto
55
11
Dublin
You can take cassette off by loosening axle clamp on disc side and pull cassette with axle out i had to do this to grease the hub as their was strange popping coming from it. Noise went after some grease as some stated on an other thread. When apart you can take the dork disc off.
KennyB
824
562
Taunton
Also, the cassette can be removed without removing the axle. You just need a chain whip and cassette tool.
Fx1
Feb 6, 2020
267
203
GB
The dork disc can be removed without taking off the cassette using a set of snips and a little common sense!
Yes that is what I did. Painful on my fingers though.
