Freehub issue
stiv674
777
600
Wiltshire
My Raceface freehub was playing up badly on Saturday so I took it apart today hoping that a quick clean was all that was required, it was full of gunk and unfortunately two of the (ridiculously tiny) pawl springs were broke so it is now beyond repair. The Raceface replacement is £109, does anyone know if there's a cheaper solution?
Bike is a year old and covered 1000 miles.
Thanks.
D
Deleted member 7464
Guest
Can you not contact raceface and see if the springs are available to buy? I would be surprised if they aint
stiv674
777
600
Wiltshire
Yeah I will do that but after reading some posts on another forum they don't seem to do spares, the springs are about 2mm in diameter! It doesn't look like a very robust system...
Dan63
289
170
Brisbane
You could always find a generic replacement - possibly at a spring specialist or a bearing/seal shop?
Mick
Guisborough
Had exactly the same problem, emailed race face, they don't stock replacement springs and no bike shop in the UK stocks springs that small.
You want 2.4mm stainless steel springs from ebay, you need to cut them to length, they do sell them as small as 5mm in length but i think even they are to long, I just got one about 3cm and cut bits of, its a bit of trial and error till you get the right length, you neen very little sticking above the hole they sit in or the pawls wont push back far enough to refit the free hub.
stiv674
777
600
Wiltshire
Thanks for that info, worth a try before coughing up for a new one (y)
6,141
4,672
Are you sure the freehub is Raceface specific? Seems to me Raceface hubs offer option for freehub types so it could be Shimano, SRAM, DT Swiss. Maybe search for spares for them and see if they match yours.
stiv674
777
600
Wiltshire
This is the same as what I've currently got...
Mick
Guisborough
From what I rember the hub/frehub are made by novatech and only that freehub will fit.
My wheels were raceface aeffect and were the worst wheels ive had, the only freehub I could find was in America and would have cost £109.
Soon after repairing the freehub the axl snapped, that took 3 weeks to get a replacement, a friend with the same wheels had his rear axl snap also, needless to say those wheels are not on my bike anymore.
stiv674
777
600
Wiltshire
Same wheels on mine, expensive to replace them though, I'm hoping changing the springs will work.
Mick
Guisborough
Replaced the wheels with Mavic E XA35 £260 the pair from bike discount de and cant fault them virtualy identical weight as the race face with a ratchet freehub, £260 for a pair of wheels with a ratchet freehub or £109 for another shit freehub!, no contest.
stiv674
777
600
Wiltshire
Well thanks to your advice I think I've fixed it, for a while at least ? for the grand sum of £3.96 :)
I may start saving for some new wheels though...
Mick
Guisborough
Glad you're sorted, cant say how long they'll last mine was still working when the axl snaped 6 weeks later, but its a cheep fix if you need to do it again, and yeah good idea start saving.
