Good lord, 60! Wow. My new hero, I am definitely getting one of the guards now!
here goes with the explanation. First a gratuitous shot of sworksie. Sorry about the yard. It’s winter and I can’t be arsed.
Next, a closer shot of the guard.. You can see two cable ties which thread through the original holes in the progaurd and the hugger below. Really tight fit of one inside the other, no glue required(stroke of luck there). The mounting section off the progaurd was neatly cut at a profile to match the line present on the hugger inside. Many inches of land at either side of the ties.
Next one shows where the mudhugger lands as standard. The overlap is hidden in the shot, obscured by the seatstay brace. About 1” of the progaurd comes through the seatstay brace. Out of shot.
A pic of where a tie goes though both elements and around the seatstay brace.
Finally(phew) A couple of pics to demonstrate the integrity of the assembly. Showing I hope, an almost total lack of deflection with alf a brew sat on it.
i believe my slight reluctance to argue with gary about the rigidity, (I had couple of sherries on board that night) when, I knew it was very sound after at least a hundred mixed miles already on it. Many more now. Sorry about that Gary old chap. Little weight left in the progaurd after stiffening and mounting section removed, and as I said a Really tight fit of the hugger inside the progaurd. No noise, little flex or deflection. Really good solution, if a little expensive. I had both elements, so not too bad.
in the last shots a line can be seen where the progaurd overlaps the hugger, and the profile where one meets the other horizontally.
View attachment 24740View attachment 24741
there we go clear as mud, sorry for the unintentional pun.
