Front Chainring/Rear Cog Size in Etube software
Dan63
289
170
Brisbane
Thanks mate, looks good and sounds reasonable on the price. ?
Heading to the coast tomorrow so i might pop into just ride on the way through
CjP
PRIME TIME
1,671
2,393
Everywhere
Do you mounted it ?
Yeah I ran it for one ride and it ran fine. I obviously must of ran it backwards which I didn’t realise at the time. I ended up buying a new bike so I put it all back to standard. It’ll be going back onto my new Kenevo when I get it next week so I’ll let you know how it goes.
SEBA
284
99
French Provence High Alps
Do you have a pic ?
CjP
PRIME TIME
1,671
2,393
Everywhere
Ok so when I ran it, I had a shorter rear shock so it had one mm clearance on the chain stay. On this bike with the stock suspension it’s just touching.
It definitely fits fine on the 2020 Kenevo
CjP
PRIME TIME
1,671
2,393
Everywhere
Looking at my brothers old Merida which has the Shimano motor, it looks like it’s mounted in the reverse position so the chainring would work the right way around
20,498
Is that your praxxis ring ? If it is, the teeth look different to the ones on mine {so you could mount it either way} it looks to be more like a normal narrow wide rather than the curved and staggered teeth I have ? If you look on the other thread, my first picture shows the standard narrow wide ring interlocked with the new WAVE CURVED teeth.
CjP
PRIME TIME
1,671
2,393
Everywhere
Factory and 36T back and front. min the picture it seems to me to be backwards but that’s because the raised bit is on the rear as per yours.
20,498
I think as per your original posts the ebike ring should have the raised bits on the front.
Nice Checkerplate .. :)
If the shimano mounts on the other side of the spider, then it would be right for front mount spider rings, but not rear mount spider rings I guess. It does mount, though I guess without the guide lugs, there is the possibility that I could move around.
Yours definitely appears to have traditional narrow wide teeth (so could be mounted either way) with symmetrical teeth and buttressed teeth supports - which is weird as it says "wave" on the ring. Where as all the ones pictured in the other thread have the wave sharks fin teeth and can only mount one way - which has staggered girly skinny teeth which don't seem to feed the chain as nicely in the lower gears.
zVbqsb-x9Enp2b42mOmBT8sMtCt4pKFGlEH8wmnSVwduf_gH-VZbcJpqhaHNYYVZHmR64klcajzCPoN-1RUaWOPUL9usLSL8wt3vxQINoU-Gnv1_UFCVEwe3YLc-GY0BKGB6GsEeCslGJ9IvEqp1qe6A95aY-Vw6aAQBGfPWveVHiiiVY3Udq8oR04iNsRvH6bz5njBEe5dWkA5vH8Db0i7F7rReOf6hRI7-L71IxlN-7tnBJjX_LNPsCquxqi6fzK0Q-ZZ5bmu2AB1JstCtZ03_rAzATssIso2zg7g_MtRS6imNtG4OwgFvbDdcikIJyrG47ggdjMcyYMVD8323kvgTQD9Wtfj1TKTT0p26yNpXYP7lXT6aQkVOeY2cph9u2LpYC0biGytQ66pIOHH6CF6EM1SxQ80MNO_NzhJ70RGbH10E7MZuGrmUptZcdxH8o8mMNgzcLgTSuGGC66wEV0AqDBcluj1G8EvG96wbR5OU70fObRqvn0Xf_8D_Yi24zohlKNrO2LWS4j53FQRGfT4J0ICLpNGjA6SvNbKQeiJHKqcW2aArSSMrG9dov1UoC5GjV-KeJ-vlo1btinBRrNUkCwL249OfXz2bQ-IV9m2hrq6b9AiLkOIMhkj15kdI3CpV1SejAMIV291i2u5-VTGIpawElPRRyBN0J86pJyQYJylB5B_CuVMY=w744-h992-no
CjP
PRIME TIME
1,671
2,393
Everywhere
I don’t know man, I’m putting it back on next week when I get my new bike, I’ll let you know how it goes.
20,498
I'll be testing mine hopefully later this morning .. when I've sorted out the mudguard and it's hopefully got above 0 and some frost has gone .. :) On the positive, some of the mud will be frozen - so I can go faster !
Did you just say .. "New Bike" ?? .. ah yes .. blonde moment .. you "customised" or is that sodomised ? the last one .... :)
CjP
PRIME TIME
1,671
2,393
Everywhere
Hahaha yes replacement bike finally got approved. Suppose to be arriving Monday, I’m so excited! It’s been 6 weeks but I’ve had fun with the blue beast. So playful!
Dan63
289
170
Brisbane
Good point. The Shimano has it mounted on top of/in front of the spider gear rather than behind it like on the brose, Yamaha etc.
The praxis ring is internally threaded, so am i right in thinking the fitment on this would be poor on the Shimano and not suitable?
Dan63
289
170
Brisbane
Just read your post on the other thread... So the raised lugs are actually on the back and not the front, opposite to how it's pictured on their website? This should see it suitable for Shimano? ?
Dan63
289
170
Brisbane
I've ended up with 2 chain rings - i asked 2 shops to source me one and they have both ordered one in, does anyone want a 36T steel ring in Brisbane/Australia? I've got a a praxis ering 36T and a sram x-sync 2 36T - both steel rings. Else I may test both and just keep one as a spare.
CjP
PRIME TIME
1,671
2,393
Everywhere
Pictures please?
Dan63
289
170
Brisbane
What length chainring bolts are required to mount the praxis? It's female threaded so i feel like i might want long ones?
