What travel forks on your Levo?
What travel forks do you have on your Levo?
  • 150mm
    Votes: 29 27.6%
  • 160mm
    Votes: 53 50.5%
  • 170mm
    Votes: 12 11.4%
  • 180mm
    Votes: 6 5.7%
  • I don’t own a Levo
    Votes: 5 4.8%
  • Total voters
    105
Mike E
Bournemouth
150mm revelations , wish they were lyriks like on the new levo comp. Been looking at possible damper upgrades but have yet to find out if i can fit the charger 2.1 damper, any input on this would be welcome.
Also if i were to upgrade the brakes from the sram guide REs what would you good folks recommend???
Jeff H
205
200
San Jose, CA, USA
My original post on upgrading the Revelation damper to Charger 2.1 RC2
I'm also considering increasing the travel to 160 with a new air spring as others have done.
NathanNZ
41
51
New Zealand
I had the shop upgrade my Lyrics to 170mm. I was going for 160, but the air shafts were on backorder so went for 170. A massive improve to the rock munching abilities and stability of the bike.
NGreen
20
30
Orange County, California
I went with the Magura MT7s With 203mm rotors on my 19 levo. really like the 1 finger levers and the calipers look cool to top it off.
z1ppy
238
167
West Mids
Hmm I have 150mm but have a 160 shaft to fit.. Though I can't help but keep looking for a Yari bargain to upgrade to a Lyrik, even though my Rev's have been faultless
Peko
141
144
Why would you have a fork that is shorter than the 150mm rear travel?
If i would have 150mm in the rear, this would make sense. But i hav'nt.
Some of the older guys will maybe still know the first Levo's. With 135mm travel on the rear, it is nearly a Hardtail and not really rideable. :LOL:
The original Fork (Yari) has 140mm travel.
So i would like to have a vote for 140mm. ;)
neils
201
114
Wokingham UK
Fox factory 36 170mm GRIP2.
On the rear I already had a spare Cane Creek DB CS from and an Enduro carbon Expert(2015) at home which I then sent to TF Tuned for a complete rebuild... they changed pretty much everything and it now fits my 2019 Levo Expert and also has a 57mm stroke giving me around 163mm rear travel. Spent some proper time on the setup and researching suspension setups, worth doing if you’re buying into forks/shocks with 4 way damper control. Bike rides beautifully and is super plush. I can dial in changes for different ride types and it can handle the bigger downhills really well now. Personally for me it’s a much improved Levo and I love it! ?
Scoter
180mm!!? Who and why!?
Hell yes I did! And why not, up hill is not a problem as your motor can take up the strain. And I presume if you went up the hill your excited to smash it down. And what better tool to use than a 180mm flex at the front end. Comfort at its best.!
  • Agree
Reactions: CjP
ReinerSt0ff77
36
46
weedfield
180mm front and back with Coil.
MrSimmo
1,066
992
The Trail.
160mm airshaft on the 2020 Fox Performance, bike feels more stable downhill, haven't noticed any changes under climbing. Maybe a placebo but hey ho.
RCDallas
152
153
Italy
You can fit the Charger 2.1 to the Revelation. I haven't done it yet... waiting for a discount but I have fit a 160 mm DebonAir 2021 and changed to Maxima Plush 3wt oil in my Revelation Charger RC. Definitely an improvement over stock! Will change to SKF wiper seals once I get the 2.1 and will pretty much have a 160 Pike Ultimate when finished.
Gyro
37
19
Auckland NZ
I'm running the same Cane Creek and 180mm Lyriks, the bike climbs way better as they absorb everything rather than deflecting.
motoadve
47
27
Washington
150 mm Pike with Push ACS coil conversion and HC97 damper, best for ever!
Only reason I wont go to a larger fork is I want the angle for technical steep climbs, which to me are a lot of fun to do.
kawamaha
59
48
Monaco
2018 levo:
170mm Yari, which I liked in stock trim. After I added a shim- based HScompression it's even better. To match the fork I first milled new links to raise the rear and have more travel (150mm).
Not happy with the OEM shock I now run a longer Piggyback shock with a bikeyoke and went back to OEM link.
527K
