Turbo levo 4 adaptability - long travel, stock travel, 600Wh, no battery, trail, bike park
deanFBM
Farnborough
Currently entertaining the idea of a single bike to cover my heckler sl & dh bike.
So something I can run similar travel wise to my heckler sl for trail riding, then can be used 170mm+ travel with a 180mm fork for bike parks with no battery, so easily removable is a bonus.
I didn't like the weight of my previous FF, so would use the 600Wh battery, does it make the levo 4 feel much better?
Levo 4 seems to tick the boxes, any feedback for my use case?
Crestline. Probably the most versatile bike on the market. Can go 160mm travel f/r, 180mm travel f/r, 200mm travel f/r. An actual downhill pro has a blank for the motor area and races it as a pure dh bike. Adjustable chainstay length dropouts. Adjustable headset. It’s literally a do-it-all bike.
Can also run 600/700/800 battery
Levo 4 can do it easily. Along with the fully adjustable geometry, you can also use the range extender without the main battery for bike park stuff, it saves almost 3 kilos and still provides plenty of power in case you want it.
The only thing I’d add, because I’ve thought about this for my Levo G4, is that by the time you’ve got a spare set of forks and shock to move between long and normal travel, it’s a lot of the way towards the cost of a second hand DH bike or similar?
    676K
