Sending a battery out for renewal
Cyclopath1000
310
125
Davis Ca
I just received a brand new second Shimano e 8010 battery for my commencal meta. The original which is less than two years old and probably therefore still under warranty is beginning to show some of the typical signs of lithion ion battery problems. Performance from full to two bars is identical to when brand new but at two bars it quickly conks out which from my reading suggests one of the five stacks of ten 3.6 v Batts has one or more cell not producing the correct volts which triggers the entire ten pack to shut down. This is the natural order of things...I get that.
So there are two YouTube's describing businesses that test and replace the singles that are failing and the one is city of industry in socal sounds like they are quality as is the one in Nevada.
My question is (!forget the send it back to Shimano stuff for a moment because if not that pricey sounds like another take advantage of the good nature of my lbs) : should I do it now even though it's still good for a 17 mile 2-3k elevation ride, which is often all I'm doing , or should I wait until it deteriorates even more and just have these guys put in all new cells for around $300?
I've never seen this particular issue discussed. But I'm not on forums 24/7. It's gonna happen to all u folks btw so anybody think or act on this issue ?
Cyclopath1000
310
125
Davis Ca
I'm the only one with a weakening battery???
No one of my batteries is definitely not holding as much charge as it used too, but TBH not to an extent where I have thought about doing something about it
Yzlvr
63
16
Can you list the two companies?
Cyclopath1000
310
125
Davis Ca
These are the facilities. I'm thinking the one in so cal eventually when my batt deteriorates a bit more.
