Removing both wheels for transport?
brw0513
127
39
Brisbane, Australia
Hi all.
I still haven't purchased an eMTB yet. And after taking a walk in a local state forest today to do some reconaisance , I think I'd enjoy technical climbs and fast decents maybe even more than the trails I had in mind!
But I will need to transport a bike to ride anywhere. And I'd much rather transport it inside my car than use a rack (on roof or tow ball).
But my short wheel base Mitsubishi Pajero will require both wheels to be removed.
Is anyone else doing this? No doubt the chain would be grubby. But is there any other reason not to remove the rear wheel?
Fingerpuk
250
197
Kent
I do it. Takes 5 minutes. I kept the box of cane in and fashioned a sort of v shaped piece of card to sit it in to protect the interior.
I keep thinking if buying a Berlingo for bikes carrying but parking is an issue.
boBE
415
361
FL
I bought some vinyl flooring roll to put down in the cargo area to protect it from chain dirt.
Don't forget a small torque tool to tighten the wheel bolts, especially since you will be removing.installing then frequently. And two shims to keep the brake pads from extending too far.
Somewhat related: when I shopped for my current mini-suv the final test was that my bike had to fit. The sales droid said it was a first but went along with it as we put the bike in the back.
Beekeeper
🍯Honey Monster🍯
Aug 6, 2019
1,745
2,194
Surrey hills
Just about to do it.
2 ebikes
Wheels off
Pedals off
Seat posts out
Bubble wrap around both frames
Duvet wrapped around first bike. Second bike resting on top.
Bubble wrap around all wheels separately
will post photos when I do it.
Fingerpuk
250
197
Kent
It’s ok I’ll just use the slightly raised bit of extra road to leave it on. :)
Found a Berlingo for £800 in ok condition. Reckon it’s on if insurance isn’t silly.
Jackware
Fat-tyred Freakazoid
1,895
2,053
Lancashire
I can get my large fat ebike easily into my Ford Focus hatch by taking the wheels off. I store the wheels in wheelbags (EVOC double wheel bags are perfect) to contain the mud and water and making them easier to handle.
A large plastic lined builders dust sheet is draped in the boot and over the reclined back seats, doors etc.
If I'm leaving the car at any point I also use the back seat securing hoops on the side to chain the bike to and cover it over with black sheet.
brw0513
127
39
Brisbane, Australia
Anyone removing the chain to help get the rear wheel out?
The Connex Links seem to get good reviews from the road going fraternity - may not be appropriate for eMTB use though:
routrax
382
529
Uxbridge
I take the wheels off mine to fit in the back of my van. I put a big blue Ikea bag over the rear triangle and cranks to stop the oily bits causing problems and stick the rear wheel in another which covers the cassette. Works pretty well and the bags are about 75p.
Kaelidoz
312
304
Belgium
If you drive alone, your bike will probably have enough room with only the front wheel off.
My size L fits in a twingo 2. In a very specific position, but still.
Usually you place the fork between the back of the front seat and the rear seat cushion. The rest of the bike is either on its side or up diagonally.
Beekeeper
🍯Honey Monster🍯
Aug 6, 2019
1,745
2,194
Surrey hills
No need to remove the chain.
I often remove the back wheel when cleaning the bike. Trying to get it back in the first time was a nightmare but you soon get the hang of it and now I don’t even need to think about it.
Jackware
1,895
2,053
Lancashire
Selecting the highest gear (smallest cog on the cassette) before you stop will give you plenty of play in the derailleur to loosen the chain tension. Sram derailleurs have a small pin you engage after pushing the cage forward that locks the derailleur in a forward position to give you slack.
Bacalao
50
75
SoCal
No need to take it off to remove the wheel as others have said, but FYI I do run the Connex chain with the link on my Levo. I wax the chain so the link makes that process a breeze. I’ve run the link on Road and acoustic mtbs for years with no problems.
Its really no issue, just throw a tarp in the back of the car, take the wheels off (remembering to switch the clutch off on the rear derailleur) put the axles back in the bike so you dont loose them, chuck the bike in,, wheels on top of the bike and off you go. When you put the wheels back in to go ride ember to put the clutch back into the on position.
I have a couple of rubber garage floor matts that I put between the bike and the wheels. I also use these to protect the bike when I unload the bike, as you put them on the ground, flip the bike upside down onto the bars and saddle to put the wheels back on/off, so stops the bike getting damaged:
p3eps
1,869
2,233
Also maybe worth popping the transport blocks in the brakes incase you accidentally knock a lever when putting it in the car!
Tooks
427
516
Lincs UK
I travel with my bike in the car rather than on a rack etc, prefer it for security and fuel economy reasons, especially since I got an electric car.
Just check you’ve got everything in the car before you set off or leave, I once left a wheel in the car park at Thetford forest. In fairness, it was dark when I was packing it away, but I remembered about half way home.
I had a sinking feeling driving back, but there it was in the headlights when I got back to the deserted car park!
Bacalao
50
75
SoCal
Been there, done that! ? Fortunately same happy result.
routrax
382
529
Uxbridge
I drove off and left a pair of 5:10s in a campsite in the Dolomites (they were under my van!), ended up having to buy new shoes at my next stop in Zermatt which probably cost more than a new wheel in a country with normal prices!
Beekeeper
🍯Honey Monster🍯
Aug 6, 2019
1,745
2,194
Surrey hills
2 EMTBs inside car for our Shropshire holiday.
8,662
I bought a groundsheet from one of the the outdoor shops (Go Outdoors I think). It was designed to go inside tents, cost about £10. It folds out from 4'x3' laid in the boot (where it lives permanently), to 4'x6' with the rear seats down and it is still double thickness. The next fold out is 8'x6'. I've had it for years. Essential bit of kit to keep the boot clean
