Bike Finder · Velduro
Velduro Rogue R
Velduro
Rogue R 2025
CurrentEnduro eMTBMature · 5.9/10iFreshness 5.9/10
Avinox-powered enduro/DH eMTB
Motor
Avinox M1 · 120Nm · 1000W
Battery
Avinox FP800 · 800Wh
Travel F/R
170/170mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
23 kg
Price
From £6,750
View the Velduro Rogue R on Velduro’s site
Velduro Rogue R 2025
From £6,750
EMTB Forums verdict
The Velduro Rogue R 2025 is the New Zealand brand's flagship carbon high-pivot enduro eMTB, built around the DJI Avinox M1 motor (105 Nm torque, 250 W rated, 1000 W manufacturer-claimed peak, 2.52 kg) and an 800 Wh Avinox FP800 battery. Travel is 170 mm front and 165 mm rear (up to 172 mm with 27.5 inch rear flip-chip) on a carbon mid/high-pivot chassis with idler pulley and ASTM Category 5 DH certification. Two trims — R at £8,999 (23.6 kg) and X. Four sizes from S to XL, reach 440-515 mm, head angle 63.5 degrees flat, chainstays 440 mm flat, wheelbase 1229-1311 mm. The community read in one line: a proper sleeper of an enduro platform with class-leading rear suspension and DJI motor power, from a small NZ brand with strong UK and Australian distribution.
Drive system and range. The DJI Avinox M1 is the first-generation Avinox motor — 105 Nm torque, 1000 W peak, 2.52 kg motor weight. DJI's full smartphone tuning ecosystem, GPS, 4G connectivity and anti-theft via touchscreen display. The 800 Wh battery is removable. Real-world range will sit in the 50 to 75 km territory in mixed terrain on Trail/Boost mode. The M1 sits a generation behind the M2S (150 Nm peak) used on the Commencal and Teewing platforms, but the M1 remains an exceptionally capable motor.
Geometry and handling. Properly aggressive enduro. 63.5 degree head angle flat across all four sizes — slack territory. Reach steps cleanly 440 mm (S), 466 mm (M), 485 mm (L), 515 mm (XL). Chainstays held at 440 mm flat — short by 2025 enduro standards, giving the bike a playful feel rather than monster-truck stability. Wheelbase 1229 to 1311 mm. The mid/high-pivot suspension layout with 16T idler and oversize bearings is the chassis standout — multiple owners report this is one of the most supple rear ends in production.
Build and value. Two trims. The R at £8,999 (23.6 kg) lands you FOX 38 Factory with GRIP X2 Kashima fork, FOX FLOAT X2 Factory shock custom-tuned for the Rogue, SRAM Maven Silver 4-piston brakes, and SRAM GX Eagle AXS T-Type Transmission. The X is the higher trim. @Mikects documents the Velduro Rogue R at NZ$17,000 in New Zealand — strong value vs Giant Reign E+0 with DJI motor and 800 Wh battery.
Community-verified strengths.
  • @Durrti: "Velduro Rogue rear suspension is more supple than Crestline DJI rear suspension." Multiple owners report the rear end is the standout of the entire 2025 DJI Avinox carbon enduro segment.
  • @rabitec: "Velduro Rogue rear suspension feels incredibly sensitive compared to Yeti SB6 and Orbea Rise." High-pivot kinematics with idler deliver.
  • @Durrti: "Velduro Rogue rear suspension is significantly better than Fox Zeb fork performance, making tuned Zeb feel like hot garbage." Strong endorsement from existing owners.
  • @Plummet after visiting Velduro HQ in NZ: "The bike looks better in the flesh than it does in photos. That's one solid build." Manufacturing quality is real.
Caveats and known gripes.
  • DJI Avinox M1 is now a generation behind the M2S (150 Nm peak) used on rivals like the Commencal Meta Power SX DJI and Teewing Flux. Riders chasing maximum torque will look elsewhere.
  • Small NZ brand with growing but still limited international distribution. UK and Australia distribution is established, US is more limited.
  • @GeordieDownSouth notes a 56 lb (25.4 kg) build with coil shock, DD tyres, inserts and heavy parts — realistic enduro builds push the bike from 23.6 kg claimed up to 25 kg+.
  • Fixed 440 mm chainstays across all four sizes is short but unmodified — no size-tuning.
  • @iJak recommends 220/223 mm front rotor and 200 mm rear rotor for 90 kg riders riding hard — stock rotor sizing is on the conservative side for heavier/faster riders.
Verdict. The Velduro Rogue R 2025 is a genuinely interesting sleeper carbon high-pivot enduro from a small but well-supported NZ brand. It suits intermediate-to-advanced enduro riders who prioritise rear suspension feel and progressive kinematics over headline motor torque, who appreciate the playful 440 mm chainstays, and who have local UK or Australian Velduro dealer support. Look elsewhere if you want maximum motor power (M2S vs M1), size-tuned chainstays, or the broadest international warranty network. Production status: current, two trims, four sizes.
💬 Forum discussion
2.1k replies · 222.3k views · last reply 2 days ago
Join the discussion →
“1300mm wheelbase does look long for the given reach number in size large (485mm) and head angle. According to the geo chart the front centre *should* be 860mm in large, with the 440mm chainstay. It could be a fair bit slacker than in…”
— Rob Rides EMTB · ♥ 20 · most-liked post
OWNERS’ REPORT
Velduro Rogue — what owners actually know
2,416 posts · 179 owners · data through Jun 2026
7Shock fitment blocked by the charging-port placement · typical onset: At build time
4M1-to-M2S supersession - the customer-service wound (full story in the Avinox M1 report) · typical onset: April-May 2026
4Motor-mount creak from tight frame/motor tolerances (cured by the shims) · typical onset: First weeks of riding
One-month/500km review at 88kg: 23.7kg complete with coil, 2,000m of vert achievable in Eco - 'this is the most fun mountain bike I've ever owned' from a…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Frame
Carbon fibre enduro frame, 165mm rear travel (up to 172mm with 27.5" rear wheel), mid-pivot design, integrated battery, rear wheel flip chip, shock position flip chip, internal cable routing, Boost 12x148mm, 16T idler with oversize bearings, ASTM category 5 DH-certified
Bike geometry diagram
SMLXL
Toptube582 mm604 mm623 mm647.5 mm
Reach440 mm466 mm485 mm515 mm
Stack634 mm634 mm643.5 mm648 mm
Seattube390 mm410 mm430 mm465 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle63.5°63.5°63.5°63.5°
Seattube Angle (eff)78°78°78°78°
BB Drop10.5 mm10.5 mm10 mm10 mm
Wheelbase1229 mm1255 mm1276 mm1311 mm
Headtube110 mm110 mm120 mm125 mm
Front Centre789 mm815 mm836 mm871 mm
Trims · 3
X
£6,750
R
£8,999
Rogue R
£9,000
MotorAvinox M1 · 120 Nm · all trims
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R170/170 mm · all trims
FrameCarbon · all trims
ForkFox 38 P-S 2026, 29 inch, 170mm, Grip, 15X110mmFOX 38 Factory, GRIP X2 damper, Kashima coating, 29", 170mm travel, 15x110mmFox 38 F-S 2026, 29 inch, 170mm, Grip X2, 15X110mm
ShockFox float P-S 2026, 205X65mm (custom factory tuned for the Rogue)FOX FLOAT X2 Factory, custom-tuned for the Rogue, 205x65mmFox float X2 F-S 2026, 205X65mm (custom factory tuned for the Rogue)
HeadsetFSA No.57 Alloy MTB, ZS44/56mmFSA No.57 Alloy MTB ZS44/56FSA No.57 Alloy MTB ZS44/56
StemVelduro Enduro, Alloy, 35D, 40mm longOneUp forged alloy stem, 42mmONEUP Stem 42mm forged
HandlebarVelduro Enduro, Alloy, 35D 800L, rise 20OneUp alloy handlebar, 800mm width, 35mm rise, 35mm clampOneUp, alloy, 800L, 35R
GripsVelduro MTB grips, 22.4mm, one side ring, closed endVelduro thick grips, BlackVelduro thick grips - Black
SaddleFizik Terra Aidon X5 · all trims
SeatpostVelduro Enduro mechanical, Dia. 31.6OneUp V3 mechanical dropper, 31.6mm (180mm S, 210mm M/L, 240mm XL)ONEUP V3 mechanical Dia.31.6
BrakesMagura MT5 HC, hydraulic brake, 4-Piston, heavy dutySRAM Maven Silver 4-piston hydraulic brakesSram Maven Silver 4-Piston hydraulic brake
Rear derailleurSram eagle 70 transmission mechanicalSRAM GX Eagle AXS Transmission, 12-speed, T-Type wirelessSram AXS GX eagle transmission derailleur w/ power cable
CrankAvinox SL crank 155mmAvinox SL crank, 155mm, 34T SRAM EMTB Eagle chainringAvinox SL crank 155mm
ShiftersSram eagle 70 shifterSRAM AXS Pod Controller, wireless electronicSram AXS pod controller
CassetteSram XS-1270 10-52T Eagle TransmissionSRAM XS-1275 Eagle, 10-52T, 12-speedSram XS-1275 10-52T
ChainSram Eagle 70 Flat top ChainSRAM GX Eagle Transmission FlattopSram GX Flat top Chain
DrivetrainSram eagle 70 transmission mechanical1x12 SRAM GX Eagle AXS T-Type wireless electronicSram AXS GX eagle transmission derailleur w/ power cable
WheelsVelduro e-Enduro Alloy, EA-30Velduro e-Enduro EC-30 carbon mullet wheelset on DT Swiss 350 hubsVelduro e-Enduro carbon, EC-30
TyresFront: Maxxis Assegai M356Ru 29*2.5; Rear: Maxxis Minion DHR2 M327 Ru 27.5*2.4Maxxis Assegai 29x2.5" 3C MaxxGrip DD TR front, Maxxis Minion DHR II 27.5x2.4" 3C MaxxTerra DD TR rearFront: Maxxis Assegai M356Ru 29*2.5; Rear: Maxxis Minion DHR2 M327 Ru 27.5*2.4
Weight23.6 kg23 kg
Price£6,750£8,999£9,000
Rides similarly
Spot a mistake?
