Wild FS H10 suspension upgrades complete ?
Cb750stu
487
452
United Kingdom
Decided to treat myself to full coil suspension , Vorsprung Smashpot 160mm and a Marzocchi bomber coil suspension with a cane creek progressive spring, had a blast on it today and it's awesome super smooth , looking like I've chosen the correct spring rates off the bat ?? very easy installation on both
yolo_MTB
49
12
California/USA
Nice! Hey question.. Did you need to buy any additional mounting hardware to get the shock to work? did you have to press out any old bushings, etc? Thanks!
Cb750stu
487
452
United Kingdom
Hey man no worries, no I didn't need anything additional to make them fit, the Marzocchi came with the small teflon type bushings fitted all I did was push them out , you won't need bushings on the bottom of the shock ( upper mount on the bike) to fit it 👍👍
Great shock for the money btw 🤟
Regards
yolo_MTB
49
12
California/USA
Regards
Hey, so I'm a spazz and cant get the shock off. I have undone the bolt on the top non-driveside, but it wont come out, it just spins. On the Drive side, the 5mm bolt came off no problem. Not sure if there is somewhere I should be applying pressure or what? Any tips would be appreciated
yolo_MTB
49
12
California/USA
Figured It out. Just had to gently tap out the bolt from right to left!
