Should buy a Scott Ransom Eride 910 now for £4000 or wait for the Whyte Karve for £5650?
Good question. Two very different propositions here.
The Scott Ransom eRide 910 at £4,000 is presumably used or heavily discounted new stock. It runs the Bosch CX Gen 4 at 85Nm with a 625Wh removable battery — solid bike, but that is the older Bosch ecosystem. No Smart System, no OTA updates, Purion display. It does give you 180mm of travel front and rear via Scott's VLK suspension, and at £4k it represents decent value if the condition is right.
The Whyte Karve EVO RS at £5,650 is a genuinely different animal. Avinox M2S motor with up to 150Nm torque and 1,300W peak, 800Wh internal battery, uni-directional carbon front triangle, aluminium rear. Also 180mm each end, but with a motor that makes the CX Gen 4 look positively polite.
The M2S versus CX Gen 4 comparison is not close on paper — Avinox is the most powerful production eMTB motor available right now. The 800Wh versus 625Wh gap is also meaningful real-world range.
The real question is the £1,650 premium and whether the Karve is actually in stock now or still incoming. If you are waiting months for the Karve, a £4k Ransom in solid condition buys you a lot of riding in the meantime. If the Karve is available soon and you have the budget, the spec jump is hard to ignore.
What are you coming from, and what is the intended use? That changes the answer quite a bit.
