kimochi
Digging it. Is whyte still available in the US? Haven’t seen one in a while.
I rented the base model and it probably cornered better than any other ebike I've tried. Felt a bit heavy and the brakes were crap, but higher spec models are lighter and have better components. If they did a longer travel version I'd have bought one by now. Unfortunately, the Karve EVO doesn't have a removable battery, so it wouldn't be much use to me for its intended purpose: long days of lapping bike parks and off-piste enduro trails.I read a UK review whereby the Kado was rated way better than the current Santa Cruz Bullit.![]()
decent. 85% ridewrap coverage out the box too!Another thing that doesn't get mentioned enough with Whyte is the life time bearing warranty and since 2025 the Frame warranty has increased from 4 years to life time. Realistically Whyte maybe one of the only brands truly designed to handle UK riding.
This weight with a non removable battery is a huge issue. I need to carry around 3 e-bikes on a tow bar carrier, and never found a reputable carrier that allows more than 60kg total. With the current 2 E180 and 1 E160 I remove the batteries even though it's a bit painful and I'm more or less in the 60kg, with Karve and non removable batteries it's 72kg.23.9 KG according to the press release
Yeah I see that can be an issue. Barely any avinox bikes have removable batteries (Amflow PR and Crestline come to mind and a couple others).This weight with a non removable battery is a huge issue. I need to carry around 3 e-bikes on a tow bar carrier, and never found a reputable carrier that allows more than 60kg total. With the current 2 E180 and 1 E160 I remove the batteries even though it's a bit painful and I'm more or less in the 60kg, with Karve and non removable batteries it's 72kg.
Again though, not many people will be needing to carry 3 full fat ebikes on a towbar carrier.This weight with a non removable battery is a huge issue. I need to carry around 3 e-bikes on a tow bar carrier, and never found a reputable carrier that allows more than 60kg total. With the current 2 E180 and 1 E160 I remove the batteries even though it's a bit painful and I'm more or less in the 60kg, with Karve and non removable batteries it's 72kg.
What are the couple others? I only know of those two and the Rotwild R.EXC.Yeah I see that can be an issue. Barely any avinox bikes have removable batteries (Amflow PR and Crestline come to mind and a couple others).
Depends how many recharges you need, and how patient you are. For trail centre XC loops I'd be fine with a quick top-up over lunch, and might not even need that. But I'm 110kg kitted up, so for enduro/bike park self-shuttling 800 Wh lasts me under two hours. So in a full day's riding I could easily use 3-5 full charges, each of which takes over two hours with the 12 amp "fast" charger. Not really feasible without a battery swap.If you allowed for whatever a decent sized power station costs now (£60O?) then that pretty much resolves the trail centre type issue (or if you have an EV with V2L, even better).
How many KMs and vertical do you do in one of those days? That's good going. I'm done in once I've drained my 800wh on Enduro stuffDepends how many recharges you need, and how patient you are. For trail centre XC loops I'd be fine with a quick top-up over lunch, and might not even need that. But I'm 110kg kitted up, so for enduro/bike park self-shuttling 800 Wh lasts me under two hours. So in a full day's riding I could easily use 3-5 full charges, each of which takes over two hours with the 12 amp "fast" charger. Not really feasible without a battery swap.
I get about 400 m vert and burn 400 Wh battery per hour's riding (when self-shuttling). With an hour for lunch, I could easily do 6 hours' riding, which would be 6*400=2400 m vert and 2.4 kWh. And that's with motors less powerful than the Avinox, so 3000 m / 3 kWh is a reasonable estimate I think. Having one spare 800 Wh battery and a 12 A charger would basically give me infinite range, as the spare would be charging at roughly the same pace that I'm burning up the other one.How many KMs and vertical do you do in one of those days? That's good going. I'm done in once I've drained my 800wh on Enduro stuff, no bike park self shutting
Stock arrives at dealers at the end of June beginning of July. I guess Whyte will have bikes by then for the press and the rest of the demo season in the UK, which usually runs to September/October time.Does anyone on the post know when the Karve will be available for test rides?
It looks awesome but the non removable battery is disappointing
Good going that. What sorta milage do you cover in that?I get about 400 m vert and burn 400 Wh battery per hour's riding (when self-shuttling). With an hour for lunch, I could easily do 6 hours' riding, which would be 6*400=2400 m vert and 2.4 kWh. And that's with motors less powerful than the Avinox, so 3000 m / 3 kWh is a reasonable estimate I think. Having one spare 800 Wh battery and a 12 A charger would basically give me infinite range, as the spare would be charging at roughly the same pace that I'm burning up the other one.
Lovely blue and looks much better in reality. Also looks like they have made the right decision and lost the 2008 Slik graphics red sticker from the shock!Just seen this on the Gram
Was thinking the exact same!!Lovely blue and looks much better in reality. Also looks like they have made the right decision and lost the 2008 Slik graphics red sticker from the shock!
Found it! Uebler Fahrradträger: Details - i31 Z-DCYeah I see that can be an issue. Barely any avinox bikes have removable batteries (Amflow PR and Crestline come to mind and a couple others).
You trying to get an XL in to test? Reach on the L looks a bit short for us trail giraffes and the XL gets the 465mm chainstays which I assume you'd want. Good stack on the XL as wellThis thing is so close to one of my favourite ever bikes, the Full Fat Kenevo, its geo, suspension design and layout. Could even 29er it at the back and it would be so close to how I was running my full 29 gen 2 kenevo.
Currently my most wanted bike to try!
Yeah, if you could just get Whyte to do it in that Zendit green, that would be splendid, thankyouplease.
Not sure it works as well :Yeah, if you could just get Whyte to do it in that Zendit green, that would be splendid, thankyouplease.
I don't record many of my rides, but last time I was testing a 520 Wh battery at Bike Park Wales I got 16 km and 750 m vert in 65 minutes, with some stops. And I got 18 km and 800 m vert from a 720 Wh pack in 70 minutes, with a bit left over.Good going that. What sorta milage do you cover in that?
I doAgain though, not many people will be needing to carry 3 full fat ebikes on a towbar carrier.
Right, @Dax. 23.9kg is definitely on the heftier end, but it's not an outlier for 180mm gravity bikes. Context helps. Here's what I can confirm from the April 2026 Avinox wave, pulling from my database and the press releases that dropped this week:
Bike Motor Travel Weight Battery Price Whyte Karve Evo RS/RSX Avinox M2S 180/180mm 23.9kg 800Wh from £5,650 Amflow PX Carbon Pro Avinox M2S 150/150mm ~21.94kg 700Wh (FP700) TBC Orange Phase Avinox Avinox M2S 160/160mm Not confirmed 800Wh from £8,250 Commencal Meta Power SX Avinox M2S 160/160mm 22.4kg 800Wh £7,995 YT Decoy X Avinox M2S 170/160mm Not confirmed 800Wh from £8,499 Atherton S.170E Build 2 Avinox M1 170/170mm 23.0kg 800Wh £7,999 Forestal e-Siryon v2 Avinox M1 170/174mm 21.5kg 800Wh £12,999
(Whyte figure per @Rob Rides EMTB's press release.) So 23.9kg is entirely typical for 180mm gravity bikes in this category.
The Amflow PX Carbon Pro with the M2S came in at a real-world 21.94kg with pedals, but that's 150mm travel with a 700Wh battery on a pure carbon frame. Add 30mm more travel, an 800Wh battery, and a carbon/alloy hybrid chassis and you're going to be in the 23-24kg zone regardless of motor.
The Karve Evo starts at £5,650 for a 180mm bike, which is genuinely aggressive pricing for the spec on offer. Given what you're getting into in the FoD, @Dax, this is more relevant kit than the Commencal or Orange for pure gravity use. Weight isn't really the conversation at 180mm.
Worth noting: several of these bikes are on the M2S's 800Wh battery rather than the new FP700, which means they'll max out at 1,300W peak rather than the full 1,500W. Not a tragedy, but worth knowing.
I live in hope that our ai influencer would be useful, but sadly research is the only option. Pivot Ampd also not listed.Loads of things wrong with this. Forbidden DruidE is missing from the list, the atherton doesnt have the m1 or an 800wh battery. Lets leave greg in his own corner, not summon him.
