wrayb
Can someone tell me the weight difference between the aluminum levo frame (2020) and the carbon levo frame (2020)? No components just the frames.
I weigh every Levo we build in the shop, it averages at a half a pound weight difference. Not once have I seen one weigh 800g less2019 models.
The new carbon frame is said to save 800g in weight compared to the new alloy version.
2019 Specialized Turbo Levo E-MTB – Ten Things to Know
Interesting. I always put more stock on actual data from a person who actually did something verses something I read from a website I googled. Can you clarify...are you weighting just the frames or the entire bikes?I weigh every Levo we build in the shop, it averages at a half a pound weight difference. Not once have I seen one weigh 800g less
Carbon frame on a mtb is not about weight it is about stiffness and controlled flex for a given classification of use. Different story on a road bike.
I have weighed just frames and entire bikes. The biggest difference I have measured is 500g. I have seen weight discrepancies of up to 300g between two identically sized bikes in the same exact model.Interesting. I always put more stock on actual data from a person who actually did something verses something I read from a website I googled. Can you clarify...are you weighting just the frames or the entire bikes?
I completely agree on a regular mountain bike or road bike. On a Levo, there is no noticeable difference.Carbon frame on a mtb is not about weight it is about stiffness and controlled flex for a given classification of use. Different story on a road bike.
Given we’ve established the weights vary can you trust one Levo rides exactly the same as the next?
Since it primarily the intrinsic design of the frame that gives its ride characteristics and small weight variance would not be noticeable......even less so on an E MTB.
That does detract a little from the argument to go carbon
Exactly!!
What’s google? How does it work?
Not a weight issue. Stiffness is very noticeable. I only want to ride Carbon frames. I’ve had both.Can someone tell me the weight difference between the aluminum levo frame (2020) and the carbon levo frame (2020)? No components just the frames.
