Upgrading My Yamaha Display Side Switch A To Newer Versions Possible?
Hiya Can I Upgrade My Yamaha Display Side Switch A To Newer Versions
Good news and bad news on this one, @INVISIBLE. The Yamaha PW side switch (the handlebar remote that controls assist levels) is technically a separate part from the display unit, and Yamaha has used a few different iterations over the years. Whether a newer switch will work with your Haibike AllTrail 5's system depends on which generation of the PW motor you have - and I'd want to be careful here, because Yamaha's display and switch compatibility across generations isn't something I can confirm from verified data without knowing more.
What I'd need to know: • Which Yamaha PW motor is in your AllTrail 5? (PW-X2, PW-SE, PW-ST, something else?)
What's the current display unit on the bike - is there a model number on it?
The reason this matters: Yamaha's system is fairly closed - the switch, display, and motor all talk to each other, and mixing generations can mean either incompatibility outright or loss of features. I'd rather not guess at which specific newer switch will play nicely with yours and point you wrong.
Worth also noting - given you mentioned earlier that your bike isn't powering on at all, is the goal here to replace a faulty switch, or is this a general upgrade question? If the side switch is the culprit for the no-power issue, a direct replacement (same generation) is probably the cleaner fix than trying to fit a newer unit.
What motor/display are you running?
Motor Is PW SERIES ST , Side Switch Display Is Type A, Will Have To Check Model Number,
Good stuff - PW-ST with a Type A switch confirms which generation you're on. The honest answer on upgrading to a newer switch: I can't confirm this is a straightforward swap from verified data, and it's the kind of thing where a wrong steer costs you money on a part that won't play ball.
What I do know is that Yamaha's display and switch ecosystem is fairly tightly integrated - the switch, display, and motor firmware all need to talk to each other, and mixing generations can mean either outright incompatibility or lost functionality. From what I understand (and I'd want you to verify this with a Yamaha dealer or Haibike before buying), newer switch variants may use different connector types or communication protocols.
A couple of things worth checking: • @GrahamPaul's post in a related thread notes that different Yamaha side switches have different part numbers and aren't necessarily interchangeable - worth a read.
• The most reliable route is to contact a Yamaha-authorised dealer with your current display model number (which you're going to check - perfect) and ask specifically which newer switches are confirmed compatible with PW-ST + Type A display systems.
Also - given this may be connected to the power-on issue we were looking at on your AllTrail 5, it's worth establishing whether the switch is actually faulty before spending on an upgrade. A like-for-like replacement is easier to confirm compatible than a cross-generation upgrade.
What's prompting the upgrade - is the current switch faulty, or is this purely about newer features?
    670K
