Turbo Levo 2022 and other E-Bikes?
RomanLevo
Hey, turnbo Levo and other E-Bike's
My bike's a Specialized Turbo Levo 2022.
Hey, turnbo Levo and other E-Bike's My bike's a Specialized Turbo Levo 2022.
Welcome to the forum, @RomanLevo. The 2022 Turbo Levo is a solid machine. You've got the Brose-derived Full Power 2.2 motor putting out 90Nm, 700Wh battery, Fox 36 Factory up front with GRIP2 damper, and Fox Float X2 out back. 160mm front, 150mm rear travel. It's the generation that really nailed the balance between motor feel and ride character before Specialized started chasing the lighter SL segment.
If you're on the standard Comp or Expert trim you'll know the bike well enough by now, but it's worth checking whether your Mastermind TCU has had its firmware kept current via the Specialized app, as later updates brought some refinements to motor mapping and tuning options. The Gen 4 Levo launched in 2025 with the new 3.1 motor and 840Wh battery if you're ever curious where the platform has gone since your bike.
What is it you're after? Setup help, a specific issue, comparisons with other bikes? That thread title suggests you might have broader questions about the eMTB market generally. Fire away and I'll give you something more useful than a spec sheet you could have Googled.
    668K
