Stripped battery mounting bolts E160 RSMX 2023 Gen 4
mooby77
Alchemist
Snowdonia
Despite using the right Torx + socket I have manged to round off two of the motor mounting bolts drive side trying to drop the motor to route a new brake hose through
They were well and truly seized , steel going into alloy and they seem softer than Keir Starmer on Peter Mandelson
Any ideas on getting them out , what do use
And yes i am blaming the tools , fixings and bike , not my cack handiness :)
Cheers
Cheers
Probably a bit of galvanic corrosion going on.
Is the Torx head proud, can you carefully cut a slot in it then use a big flat screwdriver or head to get it out?
Have you tried a slightly bigger torx bit, or even a similar size hex head hammered gently into place?
Wera Torx wrenches have a unique shape that helps with situations like this. Or you can take a larger Torx bit and taper it slightly on a grinder, then hammer it in and remove the bolt.
