Spectral:On rear axle dimensions
tomato paste
220
142
I'm planning to replace the rear axle in order to install a Thule wagon adaptor, and I'm not sure exactly which Thule axle will fit. Anyone know the Spectral:On axle dimensions?
The components are listed as:
Wheel
Alexrims EM30 | Shimano Deore XT
Rim Material: Aluminium
Wheel
Alexrims EM35 | Shimano Deore XT SH11
Besides popping it out and using a ruler/calipers, are the dimensions written somewhere?
Thule has a bunch of options for axles, so there's potential for errors:
tomato paste
220
142
Looks like there a bit more info on a Neuron:On over here:
Thule Chariot
Saying 12mm x 1.5, with a length of 172/178. But it's a little unclear from the postings, or if this is the same for a Spectral:On.
B1rdie
834
1,034
Brazil
The spectral has a boost rear wheel but I do not know if the neuron will have the same.
B1rdie
834
1,034
Brazil
Ich spreche deutsche nicht ?but on that thread it seems they say the neuron has 12x148 mm rear axle witch is the same as the spectral. Boost = 148 mm internal.
tomato paste
220
142
Got it in the mail, installed, and works well. If you need to tow a Thule Chariot child carrier, this is what you need for the Spectral:On 2019:
Syntace 160-172 mm Axle Adapter
• passend für Fahrräder mit dem 12mm Syntace Steckachssystem (148 mm Boost Einbaumaß)
• Mindest- Höchstlänge: 160-172 mm
• Gesamtlänge: 199 mm
• Gewinde, Gewindesteigung: M12 x 1.0
• Befestigung: Mutter
Herstellernummer: 20110733
Thule Chariot Achsadapter Shimano Thru / Syntace / Maxle Adapter 12 mm für Chariot Kinderanhänger kaufen | ROSE Bikes
