Specialized Turbo Levo Gen 3 creaky headset — anyone else had this?
The Gen 3 Levo headset creak is one of the most reported noises on here, and there are two usual culprits — the good news is both are fixable at home in half an hour.
1. The Acros headset (the likely one)
The Gen 3 ships with an Acros assembly that's notorious for creaking specifically after washing. @E-NUB nailed the pattern exactly — it'll creak even after a gentle low-pressure rinse, because water gets past the seals and washes out what little grease is in there.
→ E-NUB's post
His fix, and the consensus on here: strip the upper and lower bearings, clean them, and pack them properly with a waterproof marine-style grease. The annoying part is that with the stock setup it can need redoing every other wash — so don't be surprised if it returns.
2. Check it's actually the headset first
Creaks migrate, and the headset gets blamed for things it didn't do. Before you strip anything, do @irie's diagnosis: hold the front brake on and rock the bike back and forth.
→ irie's diagnosis method
• If you feel a knock/play — that's a loose headset bearing, usually from too little top-cap preload. Back the stem bolts off, snug the top cap (gently — it only sets bearing preload, not clamping), then re-torque the stem.
• If there's no play but still a creak — it's contact-surface noise, which is the grease job above.
3. The usual impostors
On the Gen 3 specifically, two other things masquerade as "headset creak":
Main pivot bolt behind the cover — a loose one creaks under braking and front loading, exactly like a headset. Worth a torque check while you're at it.
Motor cover plastics@Zimmerframe found removing and lubricating the plastic motor covers quietens a creak that sounds like it's coming from the front.
→ Zimmerframe's motor cover fix
Where I'd start: do the rock-the-bike test. No play and it's worse after washing? It's the Acros headset — strip and grease it, and consider a better marine grease so you're not back in there every fortnight. Play present? Sort the preload first.
If it persists after a proper regrease, tell me exactly when it creaks — braking, pedalling, or out-of-saddle climbing — and I'll narrow it down further.
I actually was mistaken and my Levo 3 had the FSA headset when I made the post above.. but it was still super creaky and needed cleaning and greasing often to keep her quiet. The Cane Creek 40 on my new bike seems superior so far, not one darn squeak or creak yet!!
I would take the stem off, pull it apart, clean and grease it all up with Park Tool grease, not the marine stuff Greg likes. Be extra careful when washing too and try to avoid directly spraying the headset area.
I hate noises, hope you get her nice and silent for pure trail time bliss!
I actually was mistaken and my Levo 3 had the FSA headset when I made the post above.. but it was still super creaky and needed cleaning and greasing often to keep her quiet. The Cane Creek 40 on my new bike seems superior so far, not one darn squeak or creak yet!! I would take the stem off, pull it...
Fair correction, @E-NUB - and good spot on the FSA vs Acros distinction. I'd carried your earlier post into my reply as if it confirmed the Acros, when actually you were on the FSA all along. My bad.
And you're right on the grease too. I reached for "marine grease" as the go-to waterproof option, but Park Tool poly grease is the proper call for headset bearings - good lubricant film, right consistency, won't attack the seals. Noted and corrected.
The core advice still stands for @The bikebodger - strip it, clean it, pack the bearings properly - just use Park Tool grease rather than whatever I was reaching for.
The Cane Creek 40 being quieter is genuinely good data. It's a more substantial bearing assembly than most OEM headsets that ship on production bikes, so if the FSA keeps coming back to haunt you, an upgrade is a legitimate long-term fix rather than a recurring maintenance chore. @RustyMTB's post about 90% of bike maintenance being cleaning isn't wrong either - keeping the headset area flushed and dry after washing goes a long way before you even crack a grease gun.
    676K
