Question about sizing for the Levo 4: I'm 179 cm (5.87) and can fit both the S3 and S4. What will you choose and why? I'm not quite sure about it myself.
I'm same size as you, I got the S4, which fits perfectly for my preferences. Due to the steep seat angle, the rather short chain stays and the smaller 27.5 rear wheel, it feels quite compact, thou its got a 480 reach.
Anyway, if you got the chance, ride and compare both of them for your own, preferences are very individual.
Wow, first ride on gen 4 comp yesterday, wet muddy conditions, stock except tubeless, w/ Xpedo Spry flat pedals (have not weighed it). So impressive! Got used to the increased size of the downtube long ago and it is not a negative for me at all. Looks like a powerful muscle bike to me so I love it! Orange is my least favorite color so I ordered the pink champagne and it actually is quite beautiful with matte finish & black accents. It's not a girly pink.
Anyone who says Specialized butcher tires are rubbish simply has not ridden these latest versions and is passing on old news. We have extremely slippery conditions with wet, off-camber roots/greasy rocks most days of the year. Both front and rear butchers absolutely grabbed everything, and with impressive damping at very low pressures. I traded out the oem butchers on my ’22 GEN 3 for Michelin E Wilds, but these tires are fantastic and an improvement over the Michelin's. Going to keep them for sure. Was also planning to trade these tires out because I've gravitated to wider 2.6 front/2.8 rear E Wild tires in the last two years , but these 2.3's work so well they have made a believer out of me.
Electronic shifting is new for me and is a dream. So good. Maven brakes are astoundingly good. Not getting much hand fatigue on long downhills. Rare pedal strike, compared to many more on gen 3. S4 really benefits from 155 mm crank arms. Going to put them on my gen3 for sure which I'm saving for my son-in-law.
72kg kitted, 183cm, 210psi Genie shock, 75psi Fox 36, no changes to oem neutral head angle, short chainstay and shock adjuster, left all 3 of them as they came out of the box.
I simply was not aware of the weight of this bike when I was moving. The bike is so well balanced. But the software/firmware is the real winner, completely natural. I have a vicious need for speed and am used to riding in turbo everywhere (even downhill for charging the short ups), eco 40/100, trail 70/100, turbo 100/100, shuttle medium, responsiveness slow, and overrun default. I was amazed at how much better the increased power is. No surprises as it rolls on. Can climb things that I often failed or really struggled with on gen 3. It's like you start to climb expecting to have to really dig deep at some point, then you finnish and realize wow didn't need to! Traction control is an amazing improvement. You get to the place where you expect to hear the rear begin scratching as it threatens to slip and then it just doesn't happen. Understand, we have very few trails to ride where I live and so I know every inch of these like the back of my hand. On longer weekend rides, will use Eco more to get better range. Range extender not available right now, coming in July, and can't wait to try riding with just that on my shorter, race pace Thurs. rides followed by 2 hours of trail work.
Whipped battery out with my trusty screwdriver handle Bondhus 5mm before loading it up & then immediately after the ride. Amazing how easy it is with battery out to load in truck, put up on bike stand. Going to find some sort of security for the battery cover bolt for shopping trips.
No wonder this bike won the 25 E-bike shoot out comparison online @ E-Mountain Bike website after being beat out by Merida and Orbea the past three years. Gotta say, after all the negative complaints online I was worried that I would not like it. Not a chance! Really a big step up, not just a minor improvement. Definitely for aggressive riders especially, but also for beginners when they make a mistake, start to shoot off the trail, and need to correct quickly without dabbing. It's like, "you think it, it does it, almost before you realize it".
Also, on gen 3 I had to steepen the head angle to the max (+1 headset cup setting)to get it to turn in easily on our tight, insanely slippery, rooty turns. This does it beautifully in oem neutral head angle setting.
Right out of the box it rides like a winner. Highly recommended.
Hi
did you finally find a security Bolt for Battery cover?
I thought 2.3 actually is the old ones and is delivered on all bikes also yours until the stock is finished then the new 2.4 will be delivered on the bikes.
Am I wrong?
Am I wrong?
I think they mean the old, old butcher. The redesigned versions that first released in 2022 and have just been refreshed again this year were received pretty well.
My new gen 3 Levo came fitted with Butcher T9 grid trail on the front..29x2.3 and Eliminator T7/T9 Grid Gravity 27.5x2.3 rear. The bike is only used for cross country type rides and currently everywhere here is bone dry dusty and rock hard, but the tyres seem fine. I have a Maxxis Shortie DD MAXGRIP ready to fit for winter conditions.
Don't know the difference between old, old and old just read the new Butcher 2.4 is different from the old.
I have ordered a pair of Butcher grid trail 2.4 and Eliminator grid trail 2.4 both tan walls since I don't need gravity and hope they both are the new version because as far as I know 2.4 was not available earlier.
If they are 2.4s they should be the most recent ones.
Thank you very much for that response. I had the old Levo SL in size large. I mainly used that for trail riding. Sometimes it felt like "too much" of a bike.
The Levo 4 build is usually going to be for bike parks and long epics in the mountains. I love climbing on it, so that is also a factor. At the same time, I like when a bike feels secure on a downhill when you're just plowing down. I'm not like trick and jump kinda guy. I tried the S3 and S4 outside the shop, but it's really hard to determine.
I have a longer torso than normal. So the reach is definitely not a problem on an S4. It's just more about which one of them feels more planted or secure, Yet not too much of a bike to maneuver around.
I'm 1,80m with long legs and therefore short torso for my size which not seems your case and had:
-LEVO 2 in L
-KENEVO 2 in S4
-LEVO 3 in S4
-LEVO 4 in S4 and S3...
I've always felt that i needed and S 3,5 size as the S4 felt a bit large on flat and nimble terrain but felt very secure on steep descent and rocks.
When I received the LEVO 4 S4 it felt big but went back to store for a warranty problem.
A friend of mine gave me his LEVO 3 S3 for sale to ride with him as he had bought the LEVO 4, the bike felt so nimble and agile I could make things impossible with the S4.. so I choose the LEVO 4 in S3 back from warranty.
After riding it on my local trail I can say it's not as stable as the S4 so I still thing i need an S 3.5 but happy sor far as I could turn the flip chip in low and add a longer stem.
Hope that helps..
It’s just odd that reviews don’t mention the rattle, almost like they being paid not to. Glad Bosch fixed their rattle, this Gen 4 Spesh is a head scratcher for sure, so many issues and so heavy.
To me it seems that some Reviewers seem to gloss over more on issues like that but almost all reviews, apart from some people like this aussie guy reviewing the Amflow or the guy from Velomotion professional reviewers try to paint the weaknesses, especially for new hyped motor systems in a far too bright light. There have been many examples of this:
Bosch Cx gen 3 bikes had long ass chainstays because of Bosch specifications and in combination with outdated geometry from german manufactuers this created really wonky geometries but reviews never reall mentioned this.
The switch to intube designs and bigger batteries also increased the weight of full power ebikes to 25 kg or more but the reviewers acted like all of a sudden a weight gain of 2 or 3 kg or even more wouldn't be noticeable while mountainbiking.
Same with the MGU bikes like the Nicolaj who weighs 28 kg. Suddenly this weight is barely noticeable lol.
But the rattle of various motor generations somehow was the most kept secret. First the shimano e8000 which only occasssionaly rattles on rough sections. Never read about it in a review. Then when the Ep8 and the Bosch Cx4 came out the reviews said that the new motors were silent or unhearable. Many german review sites failed to mention the rattle for many reveiws until it was impossible to ignore because too many people on social media complained about it.
Same with the snapped Brose belts. Only when the issue couldn't be ignored anymore because social media was full of videos with people telling stories about getting their sixtht motor fitted they wrote some euphemistic articles about 'reliability issues with brose' but that 'specialized adressed and fixed them with a firmware update'.
In general reliability, long term-reviews or spare parts are issues that almost never get adressed.
So that's why I'm very very sceptical of the usual rave reviews by the usual suspects after the release of a new product.
-LEVO 2 in L
-KENEVO 2 in S4
-LEVO 3 in S4
I've always felt that i needed and S 3,5 size as the S4 femt a bit large on flat and nimble terrain but felmt very secure on steep descent and rocks.
When I received the LEVO 4 S4 it felt big but went back to strore for a warranty problem.
A friend of mine gave me his LEVO 3 S3 for sale to ride with him as he had bought the LEVO 4, the bike femkt so nimble and agile I could make things impossible with the S4.. so I choose the LEVO 4 in S3 back from warranty.
Hope that helps..
The S3,5 is a great point. That will be perfect. I feel exactly what you are writing, the S4 feels a bit large on flat and nimble terrain but feels very secure on steep descent and rocks, like my gen 1 levo sl in L.
Yes, I couldn't ride the S4 in the low flip chip and slack head angle as it was way too lazy and the wheelbase too big. The advantage on the S3 is that it is more tuneable (low flip chip for stability is great and longer chainstay), but it will mostly depend on your riding style and the best compromise for you.
For riders in the mid zones its just a preference choice. Some people like to ride bikes a little larger others like the feel of a smaller frame. I am 181 cm and prefer an S3 all day, every day.
To me it feels like I can compensate better on a frame that is too small than a frame that is too large overall. Its just that the shorter the frame, the more scarier high speed rough stuff gets that tends to buck you over the front.
You are absolutely right. This is my exact concern as well. The only thing that makes not choose the S3 is that I "think" it will be unstable. I have zero evidence for that, just pure feel. When I tried the gen 1 Levo SL size medium.
You are right, I can confirm you that the S3 is more instable, it’s my only concern comparing to the S4, no doubt about that. If I was to ride only steep downhill I Will choose an S4 for sure, but I find the S3 more playfull and able to improve my skills… no matter your choice you will have a great bike and get used to it..
S3 it is. Thanks so much for your inputs.
That's interesting. Could you elaborate on why you chose the S3 with your 181?
I have been riding Specialized for years and my height has always placed me somewhere between S3-S4. I have ridden both and over time have found I prefer a smaller frame, it really is a preference thing. I have been road riding for years and I would tell everyone... regardless of the frame you should go get a bike fitting! People spend 10K on a bike and don't pay $300 to have the bike adjusted to their actual build. The sizing guide is just that... a guide. I can ride either an S3 or S4 and can be properly fit into either. Lastly, in MTBs I have always preferred a smaller frame as it easier to throw around, its a bit lighter and have always felt more nimble. Again, get fitted for your bike and you will know if the frame is the correct size.
Hi,
I am expecting my levo to be ready in the next few days.
I wondering what are the best settings in the app for getting much elevation.
Any ideas recommendations?
Vheers
Dave
I'm pretty new to mine, but I've been very pleased with the range. Dynamic microtune around 20/100 - 40/100 will make you work for the power and will thus extend range.
Based on my most recent ride which I did at 25/100 I got 10 miles and 1600 feet for 20-25% battery.
Hi,
Vheers
Dave
there isn't really an answer to your question. It's something you're going to have to figure out as you play with the settings.
However, lots of guys are getting good range on -AUTO setting.
00/00? Honestly this is going to be person by person, -Auto is descent for range, but there are other variables to consider. If you are looking for absolute max range then your going to tune down the setting to the lowest setting per your fitness level. The one thing I have learned about this bike is it will use the power you give it, especially if you climb at a constant cadence. For example if you set it at 25/25 and your fitness level allows you climb continuously at 70 rpms then that bike is going to use a constant 25% of 666 watts (166 watts). On the flip side you will use very little power on the descents, so it really all comes down to the terrain you are ridding, your fitness level, and the level at which you set the bike. I can tell you for certain that micro tuning will conserve more juice the -Auto, but that doesn't accounting for your fitness. Hope this Helps, regardless you are going to need to play around with the bikes tuning to max its distance for you specific riding needs.
I am 178cm,
I rode a GLP3 size M before
460 reach
1255 WB
So, i ordered the S4 which have the the same WB but a slightly bigger reach 480mm, + 2cm
Since the day one on the S4 i feel something strange i can't tell you exactly what.
It is just hard for me to play with my body weight.
After 500kms and 3 races, it was clear that the bike is too "big" for me.
My LBS lent me an S3 and the smile was again on my face!!
It was more playfull, even in fast steep downhill, my confidence was back.
So, i sold the S4 and bought an s3 🤷‍♂️
I would say, bike size really depends on riding style.
I would suggest for those who are between 2 sizes, to go with the size down if you have an active and agressive riding style and go to a size up if it just for all montain trail and light enduro.
I am 178cm,
460 reach
1255 WB
Thank you very much for your insightful input :)
    Join 43,110
