sduro fullseven 7.0 suspension upgrade
MsO
258
168
swindon
Hi all is it possible to upgrade the forks and rear shock on my haibike its currently got 120mm of travel looking to go upto 160mm of travel its a 2018 sduro fullseven 7.0 and what forks and shock to go for????
MsO
258
168
swindon
OK lets try a different way:) Can anyone recommend a good bike shop around the Wiltshire area that could give advice and carry out the upgrades on the suspension
AJR
48
48
Essex
You cannot increase the rear travel by changing the shock. The rockers drive the shock and you could not change the stroke to allow that sort of travel as the frame is designed around that shock and travel. That is why the different travel bikes have different rear ends and pivot points. You can fit a longer travel fork, this will change the head angle and bottom bracket height, so I would suggest you do not go to long on travel as you may not like how the bike handles after fitting them.
