Ride control
StevieG
lancashire
It is very annoying that it doesn't connect first time, Iv'e found if you keep disconnecting then re-connecting it will eventually connect. To be honest the only thing you need to connect for is updating software and checking the exact battery level.
MacManx
Isle of Man
Just had a new speed control sensor fitted and now the app won’t connect to the bike. I’ve uninstalled and installed it several times, tried all the above and it still won’t pair the bike to the app.
Any suggestions? The bike is a 2019 Trance E+ SX Pro.
Tony.OK
191
234
Napier, New Zealand
Just had a new speed control sensor fitted and now the bike won’t connect to the bike. I’ve uninstalled and installed it several times, tried all the above and it still won’t pair the bike to the app.
I just uninstalled latest app, disabled auto updates on ph, then installed older 1.4.2 app and can connect to my 19 e+1 again, bottom of page is older versions of app, be sure auto update is off before opening app or it will try to update to latest app that doesn't work properly.
MacManx
Isle of Man
Hi Tony
Thanks for the info, I’ve installed version 1.4.2. and it’s still not connecting. It picks up the bike when I scan for connections, just won’t pair. I only want to connect so I can alter the power settings, not bothered about any of the other functions as I’ve paired the bike with my Garmin 520 which shows me the exact amount of battery remaining, power level and also maps my ride.
Shifty
249
442
Wiltshire
My bike had an updated ride controller on the handle bar (Giant Trance E Pro 3) last month under warranty, this connects a whole lot better now.
Captmike101
Gardnerville, NV
I am very disgusted with Giant and their choice to ignore all the problems with this app and its functionality. My primary motivation for purchasing my Stance EMTB was the inclusion and marketing of the App instead of a full function computer on the handlebar such as all the competitive bike companies provide. My dealer has hit a dead end on this matter after exhaustive efforts to get support from Giant. I have tried to call and left messages, emails and a certified letter to corporate as well without even one word of response.
I feel all who are dissatisfied with the system should band together and seek a resolution via any and all means available to us as consumers.
All replies on this matter are welcome.
