Unanswered Replacing a brake caliper
Grant Allan
14
Wellington, New Zealand
Hi guys,
I stuffed up and damaged the pistons in my br-mt520 shimano caliper while replacing my pads.
Replacement calipers are almost impossible in New Zealand at the moment.
So what can I use instead? Maybe from sram or another model shimano.
On a side note I've had a new pair of pistons made from mild steel though I'm a little unsure about trying them incase the metal heats up expands and seizes in the caliper or the heat cooks the fluid.
Grant Allan
14
Pick another caliper that uses the same fluid.
no clue what you’re saying about the pistons. If they’re for the caliper it should be fine. If they’re solid mild steel made in your garage then lol but maybe they’ll hold until you get something legit in. I wouldn’t run any ghetto stuff for front brakefor sure.
This is what I had made up. Just wish shimano would sell a rebuild kit.
RustyIron
1,533
2,409
La Habra, California
The coefficient of expansion for steel is half of that for aluminum. Your caliper heats up, too. The big question is how much clearance you allowed between the pistons and the caliper. Assuming they work ok, the bigger problem will be corrosion of the pistons. I don't think steel is the best choice of materials.
fenwick458
295
187
Cumbria
all shimano impossible, or just MT-520?
if you can get any Deore, SLX, XT, XTR, Zee, Saint they will work. Deore BR-M6120 looks exactly the same....
a friend told me recently he was struggling to find a lever for his and was told any shimano lever is interchangeable, so by that logic then all the callipers are interchangeable...
525K
