Removing rear wheel Rise H15
TimC7
Ovine Assaulter
Apr 22, 2023
200
740
Is there an easy way to remove the rear wheel that doesn't require 3 hands? I raise the rear off the ground with a stand, put the bike into top gear, turn the clutch to off, remove the axle whilst holding the wheel with one hand, move the derailleur chain tension arm fully forward with other hand and then need a third hand to lift the chain off the cassette . . .
irie
2,025
1,972
Chichester, W.Sussex, UK
Turn the bike upside down.
mike_kelly
898
724
US
IN most derailleurs there is a lock to hold the pulley assembly out of your way.
Shjay
835
488
Kent
The lock is only on Sram derailleurs. Best way to remove wheel is have bike upside down, change gear to smallest cog then one hand on derailleur other on tyre removing the wheel
