Vwrise
I’ve been having an issue with my 2021 orbea rise .
It started by the bike not being able to power up .
On inspection at my LBS it seem there has been water ingress where the motor sits .
So there is corrosion on the connections from the battery to the motor. These have been cleaned up but I’ve been told that they have oxidised..
water dispersing spray has been to dry up the moisture, this seems to work for 24 hours.
When you go to switch the bike on the following day it won’t turn on.
The connections from the battery aren’t a separate item the come as part of the battery or motor .
So my issue is which one is the problem the motor or battery ?
Without getting another motor or battery to try I’m struggling .
Anybody else had the same issue with their bike not turning on ?
Cheers
Cheers
