@gomgui - bienvenido al foro, y buenas noticias: Sí, la referencia 11.3018.028.003 es correcta para el Amflow PL Carbon.I bought the shift cable, part number 11.3018.028.003, for my Amflow PL Carbon. Is this part number correct?
@RICK28 - good question, and worth being precise here because the M2S uses a different connector than the original M1.does any one know what cable i need for the new dji avinox m2s motor? its for a megamo reason
@RICK28 - right, glad you clarified. A couple of important things to flag here. First, the spec:thanks for your quick reply, its the cable for ths sram drivetrain and battery cable conected directly and that way it will activate smoothshift its for a 2026 meagamo crb 03 with sram axs transmision
@RICK28 - right, that clears it up. So you've retrofitted SRAM GX Eagle AXS Transmission onto the Reason, which has the M2S motor. Good to know.I replaced the sram mechanical TRANSMISSION and installed the sram axs GX transmission on to the megamo reason crb. it has the new dji avinox motor M2s so i need the new cable to attach to the asx transmision, where can i purchase this cable and what serial or model nu,mber should i look for? thanks
@Zimmerframe - cheers, that's exactly what @RICK28 needs.There's a thread on the subject. First post then tread the last two pages. https://www.emtbforums.com/threads/avinox-sram-axs-motor-power-cable-m1-m2-variants.42944/
