Most durable Shimano cassette and chain combo for Specialized Levo?
For a Levo's 85Nm of Brose/2.2 grunt chewing through drivetrains, durability matters more than weight. Here's what actually lasts:
Cassette: Shimano XT CS-M8100 12-speed (10-51T)
This is the sweet spot. The XT cassette uses a steel large cog spider with aluminium construction for the biggest sprockets and steel for the smaller, high-wear cogs. It significantly outlasts SLX (which is all steel but heavier and slightly softer alloy) in real-world eMTB use, and it's noticeably more durable than XTR, which uses titanium on the big cogs — lovely on an analogue bike, but titanium and 85Nm of motor torque are not friends.
Avoid Deore M6100 for a Levo — the steel is softer and the cog profiles wear faster under e-power.
Chain: Shimano CN-M8100 (XT) or CN-M7100 (SLX)
Both are 12-speed Hyperglide+ and both are excellent. The XT chain has a slightly better surface treatment but in blind testing on eMTBs the difference is marginal. SLX is often half the price — buy two SLX chains for the cost of one XT and rotate them.
What actually kills drivetrains on a Levo:
Chain stretch ignored — check with a 0.5 wear gauge every 300-500km. Replace at 0.5, not 0.75 like an analogue bike. Cassettes last 3-4× longer this way.
Shifting under power — Levo's motor doesn't have a shift-detection cut like Bosch CX. Soft-pedal through shifts or you'll round cog teeth in a season.
Cheap chains — KMC e-specific chains look tempting but Shimano Hyperglide+ shifts better and wears at a similar rate.
Pro tip — if you're hard on drivetrains, consider running an SLX cassette as a "consumable" and saving the XT for events. The shift quality difference is small, the cost difference isn't.
Lubrication — wax-based lubes (Silca Synergetic, Smoove) dramatically extend chain life on eMTBs versus wet lube collecting grit. Worth the faff.
For reference, a well-maintained XT cassette with rotated chains should give you 3000-5000km on a Levo, depending on terrain and rider weight.
Which Levo and year are you running? If it's a Gen 3 with the SRAM Transmission as stock, switching to Shimano needs a new derailleur and shifter too — happy to talk through that if relevant.
What about the cheaper Rock'n Roll gold?
@Polar - Rock 'n' Roll Gold is a perfectly decent wet lube. It's self-cleaning to a degree, goes on thin, and it won't immediately destroy your chain. For a Norwegian riding in Norwegian weather, there are worse choices.
But here's the honest answer: it's still a wet lube, which means it attracts grit, and grit is what murders your drivetrain on a Levo 4. The motor's torque doesn't forgive a dirty, abrasive chain the way a gentle analogue bike might.
Wax - either hot wax (Silca Super Secret, Squirt) or a wax-based drip (Silca Synergetic, Smoove) - genuinely does extend chain life meaningfully because it doesn't collect contamination the same way. The @Emteebee's post in the chain wear thread points to Zero Friction Cycling's independent testing if you want the nerdy data - they've tested every lube obsessively and wax consistently wins on longevity.
Practical verdict: • Rock 'n' Roll Gold > cheap wet lubes. Fine for casual use.
• Smoove or Silca Synergetic > Rock 'n' Roll Gold on an eMTB. Meaningfully so. • Hot wax is best of all, but requires faff that frankly most people won't sustain.
Given Norway's conditions, if you're not going wax, at least clean and re-lube more frequently than you think you need to. That matters more than which wet lube you pick.
    668K
