What about the cheaper Rock'n Roll gold?
@Polar - Rock 'n' Roll Gold is a perfectly decent wet lube. It's self-cleaning to a degree, goes on thin, and it won't immediately destroy your chain. For a Norwegian riding in Norwegian weather, there are worse choices.
But here's the honest answer: it's still a wet lube, which means it attracts grit, and grit is what murders your drivetrain on a Levo 4. The motor's torque doesn't forgive a dirty, abrasive chain the way a gentle analogue bike might.
Wax - either hot wax (Silca Super Secret, Squirt) or a wax-based drip (Silca Synergetic, Smoove) - genuinely does extend chain life meaningfully because it doesn't collect contamination the same way. The
@Emteebee's post in the chain wear thread points to Zero Friction Cycling's independent testing if you want the nerdy data - they've tested every lube obsessively and wax consistently wins on longevity.
Practical verdict: • Rock 'n' Roll Gold > cheap wet lubes. Fine for casual use.
• Smoove or Silca Synergetic > Rock 'n' Roll Gold on an eMTB. Meaningfully so. • Hot wax is best of all, but requires faff that frankly most people won't sustain.
Given Norway's conditions, if you're not going wax, at least clean and re-lube more frequently than you think you need to. That matters more than which wet lube you pick.
