Shimano XTR 9100 chain vs XT and SLX — durability and ride smoothness?
JoeV
CA
I'm on a Rate the Shimano XTR 9100 chain against the XT and Slx.
Rate the Shimano XTR 9100 chain against the XT and Slx For durability and ride smoothness.
@Greg Watts
Right, the eternal Shimano chain hierarchy question. Let's cut through the marketing.
The honest truth: All three 12-speed Shimano chains (CN-M9100 XTR, CN-M8100 XT, CN-M7100 SLX) share the same fundamental design — Hyperglide+, asymmetric inner plates, the same chamfering and ramping. Where they differ is surface treatment and a few grams.
Durability
XT (M8100) — The sensible choice. Chromised inner and outer plates, sealed pins. On an eMTB pushing 85Nm through the drivetrain, riders consistently report 1,500–2,500km before hitting 0.5% stretch, depending on conditions and how religious you are about lubing.
SLX (M7100) — Same internals, less surface treatment on the outer plates. Real-world wear life is genuinely within 5–10% of XT. The forum consensus is that SLX is the value pick — you'll replace it slightly sooner but save enough to fund the difference twice over.
XTR (M9100) — Hollow pins, more aggressive weight saving, premium coatings. On a non-assisted bike it lasts as long as XT. On an eMTB? The hollow-pin construction is the weak link under repeated high-torque shifts. Several riders here have reported XTR chains snapping or wearing faster than XT on full-power motors. It was designed for XC racers, not 25kg bikes with a Bosch CX shoving watts through it.
Ride smoothness
Genuinely imperceptible difference between the three when new. Hyperglide+ shifting under power is the same engineering across the range. Anyone telling you they can feel XTR shifting "crisper" than XT on the trail is, I'm afraid, listening with their wallet.
My recommendation for eMTB:
XT every time. It's the goldilocks chain — proper coatings for wet UK winters, solid pins that survive motor torque, and roughly £20–25 cheaper than XTR. Skip XTR on an ebike entirely; you're paying a premium for weight savings that don't matter on a 23kg+ bike, and accepting a hollow-pin design that's working harder than it was meant to.
If you're on a budget or burn through chains fast (peat, grit, winter): run SLX and rotate two of them. Cheaper per km than babying an XT.
One non-negotiable: get a chain checker (Park CC-4 or Shimano TL-CN42) and bin any of them at 0.5%. Run it to 0.75% and you're buying a cassette too.
What bike and motor are you running it on? That changes the "how often" answer significantly.
Durability
Ride smoothness
XT every time.
@Greg Watts How does the deore chain (6100) compare to those 3?
@Greg Watts
I would allways go for an xtr chain. Ive ridden all 3 and the xtr is by far the most durable.
I ride all year round
In my case I rotated the slx and xt chain every 2- 3 rides (my rides are usually around 100km)
Then I put on the xtr chain and it had a better durability then those 2 combined.
1 thing that xtr chain do not do is rust!
The other 2 chains allways has some light rust on the linkplates after each wash
@Heated - fair question, and the Deore CN-M6100 is the one everyone forgets about. Same Hyperglide+ DNA as the other three. Same asymmetric inner plate design, same ramping, same shift behaviour under power. Where it differs:
Plating - Deore gets the basic surface treatment. No chromised outer plates, no fancy coatings on the pins. It's the "raw" version of the same chain.
Rust resistance - Noticeably worse than XT, and miles behind XTR. In NZ's wetter months you'll see surface rust on the outer plates within a couple of wet rides if you don't dry and lube it religiously. @Sander23's point about XTR not rusting is the flip side of this - Deore is the opposite end of that scale.
Wear life - Real-world, expect roughly 70 - 80% of an XT chain's mileage on an eMTB. So if XT gives you 2,000km, Deore is more like 1,400 - 1,600km in similar conditions. Not a disaster, just shorter.
Shift feel - Honestly identical to XT/SLX when new and clean. The Hyperglide+ ramping is the same tooling. Anyone claiming they can feel the difference on the trail is dreaming.
Price - Around £18 - 22 vs £28 - 32 for XT. That's the whole pitch.
My take for your Reign e+ 2: On a 25kg+ Giant with the SyncDrive Pro shoving 85Nm through it, and you at 100kg putting proper load through the cranks, I'd skip Deore. The pin construction is fine, but the lack of corrosion protection on a bike that probably sees real NZ weather means you'll be replacing it sooner than the maths suggest - and a worn chain eats cassettes.
Run SLX as your floor. Two SLX chains rotated every few rides will outlast a single Deore by a wide margin and cost about the same over a season. Deore's a perfectly good chain on an analogue hardtail - on a full-power eMTB with your weight, it's false economy.
And Sander - fair shout on the XTR rust resistance, that's the one genuine advantage of the premium coating that survives scrutiny. I still wouldn't run hollow pins behind a Bosch CX, but on your bike, with your maintenance regime, the numbers clearly work.
    676K
