Megamo eBikes: range, specs, pricing and reviews?
Hey @Greg Watts, Please tell me more about the Megamo Ebikes, the range, specs, pricing and well as reviews.
@Chubba - good timing, Megamo's been coming up a lot in your recent conversations about motors and range, so here's the full rundown. What is Megamo?
Spanish brand, been around since 1991, historically best known in southern Europe but now selling across the UK and further afield. They build their eMTBs around DJI Avinox and Bosch motors depending on the model - and the 2027 range has just dropped with some meaningful updates.
The 2027 Range
ModelCategoryFrameTravelMotorBatteryFrom
Reason CRBEnduroCarbon160/160mmAvinox M2S800Wh (integrated)£5,999
Reason Air CRBTrailCarbon140/140mmAvinox M2S800Wh (integrated)£5,099
Reason Air ALTrailAlloy140/140mmAvinox M2S800Wh (integrated)£4,249
RyalEnduroAlloy160/160mmAvinox M2S800Wh (removable)£3,999
There's also the Flame CRB (2026 model, still current) - that's the one that runs Bosch Performance Line CX Gen 5 with a removable 800Wh PowerTube, 170/160mm travel, from around £4,941. Slightly different proposition - more trail-oriented power delivery and better range efficiency than the Avinox, which you and I talked through a couple of days ago.
The Headline Bike: Reason CRB The Reason is their flagship and the one generating the most noise. The 2027 version gets an XL size added (S/M/L/XL now), a redesigned carbon frame with cleaner lines and stiffer chainstays, and the Avinox M2S motor - 150Nm torque, 1,500W peak output, paired with an 800Wh integrated battery. That motor is the same DJI system you'll have seen discussed in the context of the Levo comparison - punchy, high-peak, but the integrated battery means no range extender option without some creative workarounds.
Geometry is aggressive: 63.5° head angle, 77° effective seat angle, size-specific chainstays (454mm on M, 457mm on L). Flip-chip adjustability gives you a ~0.2° angle tweak and ~3mm BB height variation.
Full Trim Ladder - Reason CRB 2027
TrimPriceHighlights
CRB 07£5,999Fox 36 AWL HD, Fox Float Rhythm shock, Shimano XT M8100
CRB 05£6,999Spec steps up from 07
CRB 03£7,999Mid-high spec
CRB 03 AXS£8,499SRAM AXS drivetrain
CRB 02£8,999High-end build
CRB 01£10,999Top spec, 22kg claimed
The entry CRB 07 at £5,999 is where most people start - Fox 36 AWL HD fork, XT groupset, Maxxis Assegai front and Minion DHR II rear. Solid spec for the money. The Fox Float Rhythm shock at that price point is the only thing that might raise an eyebrow - though given your thoughts on Rhythm forks on the Levo, you'll know what you're getting there.
The Ryal - worth knowing about The alloy Ryal is interesting because it has a removable 800Wh battery (Avinox RS800) - one of the few Avinox-powered bikes where you can actually swap the pack. From £3,999 it's accessible, and the geometry is still aggressive (64.4° head angle, 77° seat). RockShox Psylo fork and Deluxe Select+ shock at the entry level. Not as refined as the Reason, but the removable battery is a genuine practical advantage if range is a priority.
What's the consensus? Megamo have a strong reputation for their carbon frames - the ASP four-bar linkage is well-regarded for progressivity and small-bump sensitivity. The Avinox M2S motor is powerful but power-hungry; as we discussed, it draws harder than the Bosch CX, so real-world range on Cape Town's climbing terrain will look closer to 40-50km in mixed conditions rather than the quoted maximums. The integrated battery on the Reason and Reason Air is the main compromise - it's a cleaner bike, but you're locked in.
For you specifically, the Reason CRB 07 at £5,999 would be the natural comparison point against the Levo - similar motor philosophy, more aggressive geometry, and a Fox 36 AWL HD fork which is a meaningful step up from the Rhythm. Worth looking at the geometry against your Levo to see how they compare in reach and front centre for your height.
The 2027 Range
TrimPriceHighlights
Thanks, how does it ride?
@Chubba - happy to. "How does it ride" is the right question, because the spec sheet undersells it a bit. Here's what owners and reviewers are actually reporting on the Megamo Reason:
The headline: it's a rocket. That M2S motor in a 22kg carbon frame is genuinely silly power-to-weight. @simonali19, who bought a Reason as his first ebike, found it "hilariously fast in any mode other than eco"
- though he also flagged the weight feels heavy if you're coming off a 10kg analogue bike. For you, coming off a Levo, the weight won't shock you but the delivery will - it draws harder and hits punchier than your Specialized 3.1.
Handling - it's a proper enduro sled. The 63.5° head angle is properly slack and modern, a touch slacker than your Levo's ~63.6°, so it'll feel very planted and composed at speed pointing down the fast, rocky stuff you ride. The flip side: that slackness plus 160/160mm means it's a committed descender, not a sharp, flickable trail bike. With size-tuned chainstays (450mm S up to 458mm L/XL) it stays balanced for taller riders rather than getting wandery.
One thing worth flagging: reviewers note the stock 35mm stem feels twitchy - a 50mm sorts it - and the 20mm bar rise is a bit short on bigger sizes. Easy fixes, but worth knowing.
Suspension: the ASP four-bar gets praise for being supportive and bottomless - one owner reckons the 160mm chassis handles everything from singletrack to bike parks without feeling under-gunned. That suits your technical, rocky, fast terrain in Cape Town well.
The honest caveats: • Integrated 800Wh battery - on the Reason it's a real faff to remove (the motor has to come out). Given how much you care about range and swapping packs, that's the genuine compromise versus your removable Levo battery.
• There are water-ingress reports on the Avinox thumb switch across Amflow and Megamo - worth knowing if you ride wet. If you want the deeper owner reports, the thread's worth a read: https://www.emtbforums.com/threads/megamo-reason-avinox-160mm-travel-emtb.43839/
Bottom line: rides like a fast, planted, slightly bullish enduro bike with a motor that flatters you on the climbs - the trade-off being range discipline and a sealed battery. Want me to put its geometry side-by-side against your Levo so you can see how the reach and front centre actually compare for you?
    676K
