Levo crank arm recommendations
LordExplorer
18
18
Denver
I damaged one of the crank arms on my ‘19 Levo Comp Carbon and need to replace it. Instead of replacing with original I thought I’d upgrade both arms. After searching the forum it seems the Praxis Carbon arms are designed for Levo and easiest, but at $280usd it seems a bit steep. Are they worth it? Any other recommendations? Or should I just stick the the original arms?
SPECIALIZED CARBON - Praxis Works
20,498
I suspect if you've damaged a factory one already, you'd be far more likely to damage a carbon one a lot easier ...
Another option is Miranda, not sure if they do standard length or only shorter ones.
LordExplorer
18
18
Denver
Thx. At 6’4” I think I should to stick to 165-175 length. I was also thinking of the Hope arms
Al Boneta
Dark Rider
1,351
2,602
California
The Praxxis carbonarms are nice, but the Hope arms are a better value.
The stock arms are cheap and reliable and if I didn’t already have a set of the carbon arms when I got my S-works I’d probably run the stock arms
