Kenevo spring
Kenevo man
Huddersfield
Hi all just wondering if you could help me find a spring for my kenevo expert I'm 17 stone and i need a 106 had one sent today but it was too long when I spoke to them today they said that öhlins are producing one and it will be available at the end of August.. So just hopeing there's a chance of someone knowing of one that would fit. It's a large and came with a 88 lb spring
Thank's in advance
Check out the official Kenevo thread there's a lot of info, charts and links regarding the springs already.
The 106 N/MM (605 lbs) spring is available for the Enduro which has a bit shorter stroke - but it fits technically. But I'm not sure what negative effects that will have - it might get more progressive from the start? (really not sure)
I'm a heavier rider too and do have the 571 lbs on my Kenevo. It's exactly the right spring for my weight, but sometimes, wearing a heavy backpack and going rough, I would want to go one size up... so if there will be a stronger Kenevo spring, that might be one for me as well.
