RebornRider
I installed new bearings in my DT Swiss rear hub using a threaded bearing press. I stopped squeezing as soon as I met firm resistance. The axle turned smoothly, but with a lot of drag. I used a soft face hammer to pound on the end of the axle as if I was removing the bearing, but with less force. After a couple of hammer whacks, the axle turned much more freely. There was no lateral play in the axle that I could feel.
Assumptions and the question: I think the bearing outer races are supposed to be pushed against the shoulders in the hub. I assumed that was the source of the firm resistance. It seems as though the axle shoulders push against the inner races, which I assume is to apply preload to the bearings. I think there is a tolerance problem with my parts - either the hub shoulders are too close together or the axle shoulders are too far apart. I think this results in too much preload.
So, have any of you had this issue, and what did you do about it?
