Hope 180mm floating rear rotor
BengtWeil
21
California, USA
Is anyone running a 6-bolt Hope 180mm floating rear rotor on their carbon Rise and using a Shimano 4-piston caliper?
Are there any clearance issues and which Shimano 4 piston caliper are you using? Did you have to modify/grind/file the caliper to get the necessary clearance for the 'rotor buttons'?
Thank you for any/all fitment experiences with the Hope floating rotors.
XCDC
Uk
Can’t tell you about 180mm, but the 200mm certainly fouls the shimano brake mount on my M10 with XT 4 pots. I’m switching the lot to Hope mounts and E4/Tech4 brakes anyhow so doesn’t bother me.
BengtWeil
21
California, USA
Thank you for the insight. I like the direction you're planning on taking.
Teedyt
25
12
Kendal
How do you mount the he magnet for speed sensor ! I’ve fitted fortus wheels and hope rotors but need to fit magnet !!
XCDC
Uk
You need the magnet that fits under the disc mounting bolts. It comes as standard on the M10.
