Hope 180mm floating rear rotor
BengtWeil
California, USA
Is anyone running a 6-bolt Hope 180mm floating rear rotor on their carbon Rise and using a Shimano 4-piston caliper?
Are there any clearance issues and which Shimano 4 piston caliper are you using? Did you have to modify/grind/file the caliper to get the necessary clearance for the 'rotor buttons'?
Thank you for any/all fitment experiences with the Hope floating rotors.
Can’t tell you about 180mm, but the 200mm certainly fouls the shimano brake mount on my M10 with XT 4 pots. I’m switching the lot to Hope mounts and E4/Tech4 brakes anyhow so doesn’t bother me.
Thank you for the insight. I like the direction you're planning on taking.
How do you mount the he magnet for speed sensor ! I’ve fitted fortus wheels and hope rotors but need to fit magnet !!
You need the magnet that fits under the disc mounting bolts. It comes as standard on the M10.
