Hola.... quisiera hacer una consulta....
Gabi
zamora
Hola a todos, soy Gabi ....
Soy muy nuevo en esto de los foros, bueno es mas, es el primero en el que participo ..... con lo cual pido disculpas por adelantado si meto la pata en algun momento. ...
Entre aqui porque tengo una SCOTT E-GENIUS con 3 años ñas menos ....
Y me he bajado la APP ST UNLOCKER , y soy incapaz de asociarla a la bici. Todo el tiempo me dice ERROR y me pide que ingrese un PIN de 6 dígitos que no se cual es, intente con 6 ceros y con 123456, y nada no hay forma.
Con lo cual seguro que alguno de vosotros sabrá que debo hacer y cómo.
Por favor si podeis echarme una mano ....
Acousticmood
43
30
So Cal
Puedes preguntarle la teina donde tu comprelo? Lo ciento para mi Espanol.
20,493
Hi everyone, I'm Gabi .... I am very new to the forums, well, it is the first one I participate in ..... with which I apologize in advance if I screw up at some point. ... Enter here because I have a SCOTT E-GENIUS with 3 years younger .... And I have downloaded the APP ST UNLOCKER, and I am unable to associate it with the bike. All the time it tells me ERROR and asks me to enter a 6-digit PIN that I don't know what it is, try 6 zeros and 123456, and there is no way. With which surely some of you will know what I should do and how. Please if you can give me a hand ...
20,493
I think there were a few reasons why you can get this (other than using the wrong number) ... it's so long since I've used it though ..
Does it work if you connect with etube ?
Answers should be in here :
Or in the manual :
Stunlocker pdf manual
