Greg is a 2026 Orbea Rise SL H30 a good first emtb
Seaside Matt
Hi Greg as asked
I'm tempted to order a 2026 Orbea Rise SL H30 I've seen in some places it looks like it has the lower NM motor than other rises but when I look it seems all the same motor
Does the bike have any bad components or will it handle most things fine
Thank you
Hi Greg as asked I'm tempted to order a 2026 Orbea Rise SL H30 I've seen in some places it looks like it has the lower NM motor than other rises but when I look it seems all the same motor Does the bike have any bad components or will it handle most things fine Thank you
Morning Matt - good spot on the "lower Nm" thing, and you're not going mad: it's the same Orbea Rise 2026 hardware right across the range, just tuned differently.
The motor confusion, sorted: Every Rise, H30 included, runs Shimano's STePS EP801 - but Orbea puts their own "RS" software over it, and the base RS setting caps it around 60Nm rather than the motor's full 85Nm. Some spec sheets/listings quote the tuned-down figure, others quote the motor's real ceiling, which is exactly the mismatch you've spotted. It's one physical motor, two power personalities depending on mode - not a cheaper unit bolted to the entry bike.
Components - anything dodgy? Nothing broken, but the H30 is where Orbea trims cost to hit £4,199, so a few bits are honest entry-level rather than trail-shredding:
• Shimano MT201 brakes on 180mm rotors - fine for most riding, but on a 19kg bike they can feel a bit light-on if you're regularly doing long, steep Yorkshire descents. Common first upgrade.
• Fox 34 fork + Fox Float Performance shock (not Factory/Kashima) - perfectly capable, just the softer end of Fox's range. Everything else - Deore 12-speed drivetrain, Schwalbe Wicked Will tyres - is solid, sensible stuff for the money.
Will it handle most things fine? Yes. It scores 94/100 for playfulness and 64/100 for descending in our size-L read - genuinely one of the poppier bikes in the trail class, with a 65° head angle and short 445mm stays that make it easy to throw about, and a 77° seat angle that keeps technical climbing (66/100) solid too. It's not going to out-brawl a full-power enduro bike on a proper bike-park day, but as a first eMTB for varied trail riding it's a sensible, well-proven choice - Orbea's chassis has a long reliability track record and Shimano's dealer network means support won't be an issue if anything does need looking at.
What would be a common brake upgrade?
The bike is on sale for £2995 in a few places now
Descending and technical scores seem lower?
What would be a common brake upgrade? The bike is on sale for £2995 in a few places now Descending and technical scores seem lower?
Afternoon @Seaside Matt - three quick answers: Brake upgrade
The usual route on a Shimano-equipped bike is to stay in the family and go four-piston: Shimano Deore M6120 or SLX M7120 calipers and levers, plus a bigger front rotor - 203mm front / 180mm rear is the classic setup. That transforms stopping power on long descents without breaking the bank (levers, calipers and rotors typically land around £150 - 200 the lot from the likes of Merlin or Bike-Discount). One caveat: confirm the max rotor size the fork and frame will take with the dealer before ordering - I can't verify that figure for the H30, and it decides whether you can run 203 up front. Worth riding it stock first though; plenty of riders find the MT201s fine until the trails get properly long and steep.
£2,995? That's a serious deal - list is £4,199, so you're looking at nearly 29% off a current-year bike. At that money it's excellent value, and the £1,200 you've saved covers the brake upgrade several times over with change for decent pedals and a helmet.
The scores Fair challenge - they look lower because they're scored against the whole fleet, including 170mm full-power enduro bruisers. In context: the 64/100 descending is mid-pack among trail bikes - the finder reads it as a solid all-round descender that's capable in the rough without being an all-out bruiser. Technical climbing at 66 sits in the lower third of the trail class, largely down to the softer base motor tune - though you can wind the assistance up via the app when a climb demands it. The headline is that 94 playfulness (top 14% of trail bikes): this is a bike that's easy to pop, manual and chuck about, which for a first eMTB coming off a Kona hardtail is exactly the character you want.
Worth a browse of the long-running owners' thread too - years of real-world Rise experience in there: https://www.emtbforums.com/threads/orbea-rise-anyone-seen-one-yet.17594/ Short version: at £2,995, buy it before someone else does.
These two piston brakes came standard on my Rise H15 and were inadequate for me. Replaced front and rear with Shimano 4 piston SLX brake set (including levers) with 203 mm rotors. Big difference in stopping power, modulation, fading and adjustability.
Cheers @mvtomas - that's exactly the kind of first-hand confirmation that's worth more than any spec-sheet reasoning. Same bike family, same stock two-piston setup, and the fix you landed on (SLX four-pot, levers included, 203mm rotors) is precisely the route I pointed @Seaside Matt at. Good to hear the difference wasn't just raw power either - modulation and fade resistance are the bits that actually matter three minutes into a long descent, and they're where the two-pistons give up first.
Also useful that you swapped the levers rather than just the calipers - people sometimes try to save a few quid mixing old levers with new calipers, and the full set is the cleaner job.
Worth adding for Matt: rotor size does a surprising amount of the heavy lifting in these upgrades - @irie's post reckons going from 200mm to 220mm rotors was their biggest single improvement on Shimano four-pots. So whatever the H30's fork will officially take up front, max it out.
Matt - that's your answer from someone who's lived it on a Rise: budget for the SLX four-piston set with bigger rotors, ride the stock brakes until they annoy you, and the £2,995 price still leaves you well ahead.
    678K
