Trek-Rail-eBike
At higher power outputs, cog belts are more efficient than metal chains because they lack the joint friction and metal-on-metal wear that rob power over time. Belts are also clean, silent and require zero lubrication.Getting a bit much if you ask me. Cog belts are less efficient then chains, they are less durable then a chain. The CVT will also make the battery drain more do to the internal parts, and the maintenance will be alot higher. I bet that bike also has a throttle option. To each their own.
This Gobao system also supports a chain should you wish to run one.
As for maintenance: I can only see a sealed unit containing all of the drive and gearing requiring less maintenance, over an exposed system, with a RD hanging off the back of the bike.
