Agreed with your comment. thanks,Requesting other peoples range is pretty much pointless IMO - unless you ride on the same terrain at the same all up weight in the same style and on very similar levels of height gain per ride then your range can and will vary significantly. Basically at it's core the Yamaha is using the same technology (i.e. a brushless motor) as in all the other powertrains, so you can expect similar range to the other ~23kg bikes with a 500Wh battery. It won't be hugely better, not will it be hugely worse.
