Front chain ring 2018 levo
nickthebee
125
29
henley
Hi anyone know the answer i have the standard front ring on whats the best to change it to for a bit more power would it be a 36 any one know what product
khorn
980
1,054
Denmark
what would you fit
I would fit a steel chainring for a start, if you are running out of gears on the fast bits I would go for 36t. Praxis sells them and that will be my next(running alu now and can’t recommend that)
Karsten
nickthebee
125
29
henley
It will fit but it will not last very long, I have a Renthal and it is almost dead after 600 km. Alu is simply too soft when you together with motor put that much power down. If you go for that ring you also need to buy bolts and nuts and the nuts need to be as short as possible.
Karsten
so the best one is the steel one do you have a link for that pls im not that good on the pc
khorn
980
1,054
Denmark
Do you have to add chain links when moving up to a 36T chainring?
My best guess is no if you stick to the 11-42 cassette. I went 11-46 when I changed the chainring to 36 and I had to add 2 links over the stock 116.
Karsten
