AaronJones509
Hi all,
Have a 2021 vitus e-sommet which I am trying to carry out frame bearing replacement on. I have the rapid race products extraction tools however I’m unable to remove the double bearings from the shock linkage, the double bearings from lower rear linkage. Am I missing a trick or are they just stuck In the frame?
Also what tool do I need to remove the bearings from the lower frame linkage? Do I need a bearing puller?
