Fantic 180 custom build
Tim29
421
548
Left the building
2019 Fantic 180 R, spool valve fork and shock with 185mm front travel 190mm rear travel.
225mm rotors front and rear, Tnt carbon wheels on hope4 hubs front and rear, Tnt chain slapper, chain guide, carbon rental bars with rental 35mm stem, Braking carbon metallic brake pads.
2.6 Mary up front and 2.8 eddy rear. Tnt brake caliper mounts, Cush core rear,
Tim29
421
548
Left the building
On my personal bike i don’t see a reason to carry the weight up front and ebikes already nose heavy. Also only use snake skin case Mary.
In this case the customer just asked me to duplicate what i have on my bike.
With the wide 36.5 internal 29 wheel the side wall is stout and you can run 18-24psi with minimal tire roll and have never broken or dented a front wheel.
In the rear i find i can lower my pressure from 40 down to 28-34 with the core.
And the bike owner only runs 20-24 psi in rear. He a mid pack cat2 enduro rider on his good days.
20,492
he front i found a bracket i just have to machine down a few mills, but the rear i Have to make from billet
Great build, amazing attention to detail - looks fantastic . It's a beast !
What is it with all these commuter bikes on here at the moment though ? ;-) :)
Tim29
421
548
Left the building
Loving my 160 now I've got it sorted ?
Keep an eye on your lower chain stay pivot bearings there poor quality front factory and fail quickly.
Once they fail they are quite challenging to remove.
Recommend replacing with a good quality max bearing before they fail
