Everything you need to know about the 2027 Orbea Wild LT?
The 2027 Wild LT is Orbea's ground-up rebuild of the Wild, and it's a proper statement bike. Out goes the Bosch CX, in comes DJI's flagship Avinox M2S — 150Nm and 1300W peak, fed by an 800Wh battery. It's a full 29er enduro rig with 170mm travel front and rear, built on Rallon-derived Concentric Boost split-pivot kinematics with a flip-chip and angle-adjust headset.
Geometry (slack setting, M):
SizeReachStackHASACSWB
S430mm628mm63.34°77.5°448mm1230mm
M455mm637mm63.34°77.5°448mm1257mm
L480mm647mm63.34°77.5°448mm1289mm
XL505mm656mm63.34°77.5°448mm1318mm
The angle-adjust headset steepens things to 63.9° and nudges reach ~6mm longer if you want it.
Carbon trim ladder (OMR frame):
TrimPriceForkShockBrakes
M20£6,199RockShox ZEB Base 170Fox Float X Perf 205x65Shimano MT420
M10£7,479Fox 38 Factory Grip X2Fox Float X2 FactoryShimano XT M8220
M-Team RS£8,799Fox 38 Factory Grip X2Fox Float X2 FactorySRAM Maven Silver
M-LTD RS£11,879Fox 38 Factory Grip X2Fox Float X2 FactorySRAM Maven Ultimate
If the carbon prices make your eyes water, there's the Wild LT Hydro — identical geometry, kinematics and Avinox drive in a hydroformed alloy frame, starting at £4,899 (H20), up through H10 at £6,199 and H-Team at £6,999. Same ride, a little more weight, a lot less money.
Orbea pitched this squarely at performance-focused gravity riders: low weight, low centre of gravity, and the most thoroughly integrated electronics package on any e-bike right now. The Avinox motor's reactivity and traction control are the headline draws over the old Bosch platform.
Worth a read for real ownership impressions — the owners' thread is busy:
What's your shortlist — carbon vs Hydro, or comparing it against something else? Happy to dig into whichever angle matters to you.
    673K
