I've ordered the Wild LT M-Team Mullet in Large. Here is the geometry for the Mullet in Large with a 170 fork in the High flip chip setting. Below are the geometry categories I would like to see how they change with a 180 fork. Wheelbase - 1288.03mm Bottom bracket height - 351.8mm Head tube angle - ...
Good - now I've got an exact baseline to work from, which is much better than me guessing where your numbers land.
The honest position hasn't changed: Orbea doesn't publish a geometry chart for the Wild LT Mullet on a 180mm fork, so I can't hand you a verified second row. What I
can do is give you the directional shift from a 10mm taller fork, applied to your confirmed 170/High numbers. These are estimates from the geometry, clearly flagged as such - not a spec sheet.
A 10mm increase in axle-to-crown rotates the whole front end back around the rear contact patch. Rough rules of thumb: •
Head angle: slackens ~0.4 - 0.5°. So your 63.51° → roughly
63.0 - 63.1°.
Wheelbase: grows as the front extends and the bars push forward - order of
+8 to +12mm, so ~1296 - 1300mm.
BB height: rises slightly - the taller fork lifts the front of the frame, so the BB comes up a few mm. Call it
+3 to +5mm, so ~355 - 357mm. Counterintuitive, but raising the fork raises the BB.
Reach: shortens a touch as the head tube tips back - typically
- 3 to - 5mm, so ~477 - 479mm. •
Stack: rises with the taller front end - roughly
+8 to +10mm, so ~654 - 656mm.
| Metric | 170 fork (High, confirmed) | 180 fork (estimated) |
| Head tube angle | 63.51° | ~63.0 - 63.1° |
| Wheelbase | 1288.03mm | ~1296 - 1300mm |
| BB height | 351.8mm | ~355 - 357mm |
| Reach | 481.89mm | ~477 - 479mm |
| Stack | 645.74mm | ~654 - 656mm |
Two things worth flagging on the M-Team Mullet specifically: • Check the fork's E-MTB rating and that 180mm is within the frame's stated max - Orbea quotes the Wild LT as compatible up to a dual-crown 200mm, so a 180 single-crown is well inside that, but worth confirming with your dealer for warranty's sake.
• If the BB rise bothers you, the Low flip-chip is there to drop it back and add slackness - that adjustment is published, so it's exact rather than estimated.
If you want hard numbers rather than my arithmetic, the cleanest route is fitting the 180 and measuring BB height and head angle with a digital level - takes five minutes and beats any estimate. Happy to sanity-check whatever you get.
