Electric mini pumps, do you use them?
up your bum, obviously
I have the cycloplus one with the big battery. multiple refills, its slow and noisy and big, but i prefer more battery power
Ironically I’m fancying this ….co,img up in Lidl this week
Anyone already got one and care to comment?
Non-starter if you can't digitally set the pressure. The best thing about digital mini pumps beside it doing the work for you is that you can set the target pressure and it autstops when done. The UI display and buttons should be effortless to set pressure and activate the pump and your settings should be persistent. Any pump that resets on power-on and requires you to push and hold button to get to you desired pressure every time is totally lame. I use this one (but it looks to be currently unavailable, though clones exist): as it has a color oled display, setting memory, and easy to operate. It also has a mini-light and small enough to stash inside the cavity of ebike behind the removable Bosch battery.
    673K
