ebike storing info
scarthie99
20
leeds
hello needs some info on ebike storing i be storing the ebike in concrete prefab sheds which is out door its bit damp.just need some info ebike care with moisture get in to motor and connecters i know about the battery care.
You can buy covers for the connectors - what bike have you got? Mine are kept in a garage that gets pretty cold over the winter, so usually i will put a cover over them
Mike Smith
300
209
Derby, UK
With lithium batteries best to store in a cool place but don't charge them if there are below 0 degrees (celcius) and don't leave them for long periods discharged at freezing temps (y)
Wiltshire Warrior
563
228
Poole
bring your battery indoors - and if the shed is damp - well I wouldnt use it, after a winter in there your bike will look horrible with rusted bolts and all sorts of electrical gremlins - it would be better under your bed!
526K
