E-TUBE RIDE APP
Shaun
108
53
Saint Mary Bourne
Yes I have
Hi Andy,
I’ve tried on my iPhone without any success with the E8000.
I thought it only worked on the E6000 system?
Sorry just re read the earlier post again and I can get the E-Tube app to work but not the ride app.
I did notice there was a system update for the etube app today and a couple of updates for the motor and DI2 shifters.
Didn’t notice any advantages post updates.
stiv674
777
600
Wiltshire
Hi Andy,
I was just watching a video on embn about motors and I noticed a different shimano app on there so had a look, maybe it doesn't work with the E8000 then.
I have the E-Tube ride app, it is designed to work want he EN100 module that eliminates the display - the app is basically a way of using your phone as the display for the bike, and not much more.
stiv674
777
600
Wiltshire
Thanks, not really worth worrying about then.
flash
1,050
986
Wamberal, NSW Australia
The e-ride app actually works with any Shimano controller/display EXCEPT the e8000 colour display. You could use the EN100 or even try the monochrome e7000 display on your e8000 motor. The e-ride app works with either of these.
Gordon
Shaun
108
53
Saint Mary Bourne
Not a big fan of the Shimano display accuracy on my Focus Jam2. Compared to the GPS data on my Garmin Edge 1000 there is a 9% error in the speed and distance data metrics. In reality it means my speed restriction limit is more like 22.75 kph not the 25 kph legal limit for on-road use.
Shaun
108
53
Saint Mary Bourne
Mine is the same. Approx ~10% difference. I am using emax software to change the wheel circumference to make up the difference.
It is also worth noting that low tyre pressures used off-road will reduce the wheel circumference and you will find the difference will be greater off-road than onroad as Result
Did you manage to correct the speed error by changing the wheel circumference?
speedplus
Geldrop
Shaun, did you test my app ? it helps you to go over this limit 25/26 kph. check the site speed plus.nl
