Dji avinox- Amflow - Discussion
Did you get an extra sheet of Invisiframe in the kit to cut out patches or do you just have a PPF roll?
Ride Wrap in New Zealand do rolls of the same material. It was AUD$39 for a 2 foot by 2 foot sheet. Postage to Australia was like $5.
I also got some cheaper stuff from Aliexpress. It was like $9 for a similar roll. The material isn't as soft. Much harder to make look transparent. But you can do it. And I use it for my forks and those rectangles of double layering on the most exposed bits of the frame.
I got some extra sheets in the Invisiframe kit so I can cut out small pieces
Hoping they don't deviate from a trail bike too much with V2... maybe a shorter seat tube, slightly beefier rear triangle, longer stroke shock, and mullet by default 🤔
A photo of the second model's frame has already leaked)
Looks pretty much the same with a different charger cover? Hopefully has a normal headset on it and available in some colours!
Mtb monster showing the silver as sold out so maybe no more of those due to be delivered
The rear triangle looks more massive. And the shock isn't a trunion and the seat tube seems straighter
Looks identical to the current model, don't see any noticable changes there. They should have at least changed out that chrome logo 😂
Flip chip on chainstay is def new, head tube looks bigger? Linkage looks more burly, more similar to Cascade link.
Same charge cover and chainstay flip chip as the Teewing Flux, which is the 180/180 Enduro version of the Teewing.
Good spotting!
If I had to guess, the Amflow will likely be 160mm Front and 155mm rear to keep in "trail", perhaps with a further bump in rear travel if run as a mullet.
If they make it 170/160 it's definitely moving into enduro category, leaving trail behind which has obviously been a great seller.
Are we sure this is the "V2"? It could be a different model and the current PL remains as is for now.
I'd expect so if shops are taking preorder for them now
Wonder if it's their Enduro spec bike and when the cheaper Alloy one is gonna show up
I guess we will have to wait and see….😎
Looks like the frame will be a bit more refined with at least the extra chainstay flip chip. Hopefully no nonsense like no small frame size and forks hitting the frame on smaller sizes, lots of shocks incompatible etc
    Join 43,139
