• Warning!!
    UK Pedelec Law
    Worldwide Laws
Derestrict Orbea Rise Alu 2022
Matthew87
73
106
Sweden
Hi,
With the new Rise Alu and the bigger 540 Wh battery, does it mean you will be able to derestrict it and get the same power as a regular EP8?
I have my carbon Rise set att 85 Nm, but the power is far from a regular EP8 because it can't seem to draw enough power from the small battery.
Cheers!
ggx
711
455
Sintra
Hi,
Cheers!
Maybe the battery or/and the firmware messing with it.
Tonybro
🦾 The Bionic Man 🦿
1,316
2,974
Lancashire
I read somewhere else that the 360wh battery in the Carbon Rise cannot provide enough current for 85Nm, so in reality, although you can select 85 in STUnlocker, the battery can't provide sufficient current to provide so it is a futile exercise.
The 504wh battery might prove differently. I am no electronics engineer so can't comment.
I am happy with the Rise as is. My other bike has the E8000 and only has 70Nm anyway...
aarfeldt
713
634
Denmark, Danstrup
Hi,
Cheers!
It's not enough to set the torque to 85Nm.
You will need to raise the max watt in each level to 500watt (or 250/350/500 in the 3 levels)
576K
